Oil not reaching rockers
Old Apr 11, 2020 | 02:10 PM
Kyron219's Avatar
Just had my 69 350 rebuilt and went to prime the oil pump and I'm not getting any oil to the rockers. Just to the lifters. Using a Drill ? Maybe need a stronger one ?
Old Apr 11, 2020 | 02:18 PM
Sugar Bear's Avatar
We're the oil galley plugs installed AND the correct ones with holes in them for the timing chain and the distributor gear?
​​​​​Getting oil to the rockers can be tough but if the plugs were left out it may never happen. If the wrong plugs were put in it will cause oil starvation.
Good luck!!!!
Old Apr 11, 2020 | 02:26 PM
Kyron219's Avatar
Good luck!!!!
Yes they were. Its just strange that oil comes out the lifters and drains back into the block. I've took out the pushrods when I noticed. This and there all good and clean, So I reinstalled them and still the same problem persists ?
Old Apr 11, 2020 | 06:00 PM
OLDSter Ralph's Avatar
What RPM does your drill turn ? You might need a faster one. Is oil draining from all lifters ? What brand lifters are you using ? Is the smaller area around the lifters protruding out the top or bottom ?
Old Apr 11, 2020 | 06:12 PM
Kyron219's Avatar
[QUOTE=OLDSter Ralph;1240764]What RPM does your drill turn ? You might need a faster one. Is oil draining from all lifters ? What brand lifters are you using ? Is the smaller area around the lifters protruding out the top or bottom ?
its coming out the top and I'm using a small drill I just read onreade it could take anywhere from 20 - 30 mins using a drill but I have to get a bigger drill.
Old Apr 11, 2020 | 06:16 PM
Kyron219's Avatar
Old Apr 11, 2020 | 09:20 PM
edzolz's Avatar
[QUOTE=Kyron219;1240767]
Are you running the drill counter clockwise? That would reverse to normal drilling.
Old Apr 11, 2020 | 09:30 PM
Kyron219's Avatar
[QUOTE=edzolz;1240803]
yes
The Swede
Jan 8, 2015 10:49 AM
Finn5033
May 15, 2012 05:53 AM
piperman60
Mar 29, 2012 02:42 PM
papadoc
Apr 13, 2008 06:23 AM
