Offenhauser 5587
Old Nov 17, 2012 | 08:15 PM
a69's Avatar
a69
Offenhauser 5587
Just bought a used Offy 5587 dual quad and am looking for advice/opinions on using this intake along with a vintage set of Hooker Headers.
I have two directions possible:
1.) Heating up my '70 350 motor (#7 Heads) or,
2.) Building a '79 Olds Diesel Block I have into a high hp motor.
Either way would be a rebuild to one extent or another. I'd like to just "do it once & be done with it", as budget is always an issue. Thanks in advance for your input..........
Old Nov 22, 2012 | 11:16 AM
67Olds442X2's Avatar
Navy P-3 FE (Ret.)
Get carbs that are 500-550 cfm's maximum to use. I used 750's then 650's with my Edelbrock dual quad on a 460 ci big block with good flowing heads and they were a bit much.
Old Nov 22, 2012 | 11:18 AM
captjim's Avatar
What are your goals? Is it a max effort performance car or are you looking more for the vintage "dual quad look"?
Old Nov 22, 2012 | 02:50 PM
a69's Avatar
a69
Thanks, 67...... good to keep in mind.
Hi CaptJim, if I use the '70 350, the dual quad would be for the 'nostalgia look' more than a horsepower monster - BUT
the 350 Diesel block makeover would nothing short of NASTY hp! The bottom end can take it and would need plenty of intake.
Probably the wise thing to do would be to freshen up the '70 motor, buy a more modest intake, and use that setup in my '69.
BUILD the 350 dual offy monster and replace the sbc in my '74 GMC....
cfair
Jul 4, 2009 09:44 AM
projectheaven
Feb 18, 2009 06:45 PM
The Swede
Jul 15, 2008 09:21 PM
liggett
Feb 11, 2008 02:58 AM
martine
Feb 13, 2007 11:57 AM
