Nr.1 main bearing drilling on block
Old December 8th, 2018 | 10:52 AM
Inline's Avatar
So, i have 72' and 76' block ( using 76' block, SMW) and when dummy building it to check few clearances, noticed that drilling on block for nr.1 main bearing, blocks off half of the bearing hole opening to provide oil to bearing. Got confused when looked for my spare 72' block, and same thing + no mentions about this on service manual.
So, was this indended by factory, or do i have 2 miss-drilled blocks 4 years apart?
Old December 8th, 2018 | 12:28 PM
cutlassefi's Avatar
They’re all like that. Not an issue unless you’ll be making real decent power. Then you just elongate the hole in the bearing.
olds 307 and 403's Avatar
Out of Line, Everytime😉
They are all like that. Some people drill the bearing out and groove out from the feed hole as well.
Old December 8th, 2018 | 10:07 PM
Inline's Avatar
Thanks for confirmation to both of you. I leave it as it is then, im not going to make serious power.
mother$hip89
September 28th, 2018 01:22 PM
foo
October 9th, 2013 01:22 AM
Al2011
April 18th, 2013 06:45 AM
nj_cutlass72
March 4th, 2012 05:49 PM
procharged70cutlass
16
January 26th, 2010 02:34 PM
Quick Reply: Nr.1 main bearing drilling on block
