No Spark from my Daves Small Body HEI Conversion
Old Aug 14, 2014 | 10:44 PM
rcdynamic88's Avatar
My 1965 Cutlass just quit running tonight as I was taking the wife for a cruise. I got the car running over a week ago, and have been on several rides since then to check things out. Everything has been fine, so I decided to take the wife out for dinner in the Cutlass. On the way home it just quit on us while driving along. Had to have it towed home and now the wife isn't to hip on going anywhere in it anytime soon.
I am using one of the Dave's Small Body HEI conversions of the original point type distributor. For those unfamiliar, this conversion involves him mounting a 4-pin HEI module underneath the distributor housing and adding the reluctor and coil pick-up to the inside. You get to keep your small original distributor yet have newer HEI components. Previous experience with HEI's leads me to believe the 4-pin module has gone bad (already?). Most of the time its heat or a bad ground that take out those modules.
I won't get to start troubleshooting this thing till tomorrow. However I have some thoughts to put out there and ask others for their ideas. The module picks up its ground through the two screws that mount it to the housing. I believe the distributor housing is grounded by the fact its dropped into the block and held it place by the hold down. I was thinking of installing a "jumper/ground wire" from one of the module mounting screws to the same spot I connected the neg bat cable to the block. That would give what I would consider an absolute ground to the module. Since I don't have the module off yet, I can't tell how much heat sink grease was underneath it. I have read many discussions about how important that is, and to make sure you have the right stuff for it.
The 12 Volts for the module power comes from the original ignition wire. Dave's instructions advise you to cut the original resistance wire approx. 1 inch from the firewall bulkhead and splice in some #14 wire to the coil positive. That way you are not using the current limiting wire that was needed for the points ignition. I had 12.6 V at the coil positive last time I checked. I will of course check that I still have it there.
So, what is the best stuff to use on the back of the module to make it last? Is there a particular 4-pin module that some of you have had better luck with than others? I don't know what brand Dave uses, or if I will even be able to tell that when I get it off of there. My local Advance Auto has a tester for these things, so I know I can at least get the one I have checked out. What else can I look for that could cause an HEI ignition failure?
Old Aug 15, 2014 | 12:52 AM
Bernhard's Avatar
Are you sure its ignition and not fuel supply?
I would talk to the person that supplied the distributor if it is the module and look in to a warranty claim.
Old Aug 15, 2014 | 02:39 AM
+1 on both above.
If the fancy HEI distributor is defective, you need to talk to the guy who made it.
Let us know when you've confirmed you have no spark.
Old Aug 15, 2014 | 07:59 AM
X3 on all the above. An external ground is not required.
Old Aug 15, 2014 | 10:33 AM
Hawghead's Avatar
If it is defective I'd suggest the Mallory Unilite conversion. Still get to keep your stock distributor, can use the stock coil or an aftermarket, and no having to worry about dielectric compounds and additional ground wires. Just two screws (the one that held your points in place) and three wires (one to ignition, one to ground and one to the coil)
Scott
Old Aug 15, 2014 | 10:10 PM
Figured It Out
Turned out to be a fried HEI module. It was a matter of finding out why it got too hot. As I said, this conversion involves mounting a GM 4-pin HEI module to the underside of a points type distributor housing. Dave drills/taps two 8/32 holes for the module and machines the spot its going to sit nice and smooth. In his own instructions he describes how there are two plastic alignment pins on the module that must be nipped off in order for it to sit flush on the "new" area set up for it to mount on.
Well, when I pulled the distributor to look things over it was apparent that those tabs had not been removed from the module on my conversion. You could see some daylight under the module and it was tilted to one side with only the edge of the heat sink resting on the distributor housing pad he had made for it. I took the module to a Advance Auto for a test and it showed BAD. Just so we new the test was OK, they tried the $23 BWD Select replacement module and it showed GOOD. I nipped those tabs off of it, smeared the heat sink grease on the bottom of it and screwed it in place. It now sits perfectly flush on its spot. It should dissipate heat as designed now.
I called Dave, and even though I have heard horror stories about how hard he is to contact, he actually called me right back. He was adamant that he never forgets to nip off those tabs, and he gave me many trouble shooting tips to try to figure it out. I told him I had the distributor right in front of me, that the tabs were still in place and holding the module away from the base...He seemed rather incredulous. I didn't want to make a big deal out of it, I figure he has been doing this a long time. If my distributor is the first and last one he ever makes a mistake on, good for him. I fixed it quite cheaply and pretty darn fast, and I doubt I will have any more problems with this thing from here on out.
Old Aug 15, 2014 | 11:22 PM
Sounds good, glad you got it fixed!
As I like to say, It's always something simple, and that goes double for HEI.
Weird that he forgot to trim the tabs, though.
Hopefully, your wife doesn't hold a grudge for too long.
Old Aug 16, 2014 | 01:39 AM
I might take advantage of her pessimism about the reliability of the "old Olds". It could be a chance for me to go to the Woodward Dream Cruise later today all by myself! She would want to head for home long before I would anyway. I got the ignition fixed quick enough that I had time to finish installing a AM/FM CD Pioneer head unit. Now I even have tunes! The exhaust is a little loud since I have not got the complete over the rear axle duals on the car yet. Right now its a set of old "Purple Hornies" header mufflers that I have kept over the years just so I could start cars up after putting on headers. If I was 19 like I was when I got my first 1965 Olds 442 I would probably like the rumble. Trouble is I'm 59 now, and its just kind of annoying.
Old Aug 18, 2014 | 11:33 AM
Bernhard's Avatar
Good to see you got it fixed.
When Dave rebuilds the distributor what does he do to turn it into a HEI ?
Old Aug 18, 2014 | 08:18 PM
edzolz's Avatar
I'm guessing he uses a Mopar reluctor with a Ford pickup inside the cap. Don't know for sure, but I have heard that is what the conversion used.
Sarum
Mar 26, 2015 09:14 PM
Finn5033
Oct 11, 2014 09:46 PM
joepenoso
Jun 4, 2014 01:56 PM
Dokks74
Mar 4, 2012 08:07 AM
Young Man
Jul 17, 2011 10:34 AM
