New build, can't prime
Old Jul 2, 2011 | 09:36 AM
boondocker's Avatar
Where were you in '72?
I rigged up an old distrubutor to allow me to prime the engine, the problem is I can hear slushing sound in the pan but no oil coming out of pushrods (running clockwise). anyone been here before? any ideas?
Old Jul 2, 2011 | 09:38 AM
cutlassefi's Avatar
The pump turns counterclockwise.
Old Jul 2, 2011 | 11:10 AM
rocketraider's Avatar
Oldsdruid
As does the distributor.
Somebody with a Chevy's been telling you it's all GM again, haven't they?
Old Jul 2, 2011 | 11:51 AM
boondocker's Avatar
Yes, actually a Chevy engine building book (should have checked my Olds manual).
...when I rotate counter clockwise my drill starts to smoke and no oil (although I don't run long), do I have a blockage or is this just oil pressure?
Old Jul 2, 2011 | 11:59 AM
How big's your drill? It takes a decent amount of power to spin the pump (hence why a "high volume" pump steals a hp or two at high rpms).
Old Jul 2, 2011 | 12:16 PM
boondocker's Avatar
Craftsman Pro 14.4volt, it's an older unit
...I do see a small amount of oil pooling on one of the heads, certainly nothing obvious.
Old Jul 2, 2011 | 12:59 PM
69HO43's Avatar
A good start anyway. Get a reversible plug-in drill, something with a little more oomph and keep going counter-clockwise. That oil pooling is a good sign!
Old Jul 2, 2011 | 01:30 PM
Yeah, you need a big 1/2" drill for that - not a little battery-powered one.
Old Jul 2, 2011 | 03:18 PM
Oldsdruid
When we switched engines in the wagon seven, maybe eight years ago, went ahead and put an oil pump and timing gear in just to ward off future trouble. We used a nearly new 1/2" Milwaukee corded drill to prime the oiling system before installing the distributor, and it worked that Milwaukee hard. Can only imagine what it does to a cordless.
But dagnabit, within 4 revolutions we had oil out of all 16 pushrods! and that Milwaukee grunted...
And we were feeling so proud of ourselves til we tried to start it and after a few tries realised we'd put the distributor in 180 out.
Old Jul 2, 2011 | 04:28 PM
boondocker's Avatar
Yes I'm going to pick up a good 1/2 inch drill tomorrow, I've always liked the Milwaukee brand...hopefully they're still made in the US. Thanks for all the help guys...great site!
Old Jul 3, 2011 | 10:53 AM
Run to Rund's Avatar
I always put some moly cam lube grease on the pump rotors to help the pump prime itself. I use a 1/4" drive ratchet, extension, deep well socket taped together so nothing can fall into the engine. A few turns CCW of the ratchet has oil everywhere. No drill is needed.
Old Jul 3, 2011 | 10:59 AM
firefrost gold's Avatar
turn engine by had as you prime when i did my 400 I had to turn it over to get good flow from all push rods.
Old Jul 3, 2011 | 12:47 PM
69HO43's Avatar
If you already have a suitable drill, no sense in not using it. Hand-powered priming is for the stone age.
Old Jul 4, 2011 | 07:34 AM
boondocker's Avatar
I rented a deWalt 1/2 and it seems to turn with little effort, I'm getting oil out of most pushrods but still dry on some. I ran it for a good 3-4 min...how long does it take to prime a new build? is there any adjustment issues, i checked the lifter preload on one pushrod and it was in spec, tightened down the remaining rockers. Note: I blocked of the rear Cam plug as I still haven't installed the new one (can't get it installed because of engine jig obstructions).
Old Jul 4, 2011 | 10:18 AM
boondocker's Avatar
I'm getting steady drips on all push rods on right side head, missing oil at #1 exhaust, #5 and #7 on left head.
Old Jul 4, 2011 | 10:27 AM
put a socket on the crank and turn it by hand while priming and the others should start to flow.
Old Jul 4, 2011 | 10:52 AM
boondocker's Avatar
Yes I've been doing that as well, I'm noticing all my intake pushrods are starting to flow, 3 of my exhausts are still dry. I'm thinking I should have primed the lifters before installing them, I was told otherwise...it appears that this will take some time...I'm taking a break to let the drill cool down...only 3 lifters to go
Old Jul 4, 2011 | 04:03 PM
boondocker's Avatar
Well in the final analysis patience is a virtue, my god it took over half an hour of continuous running to prime this beast...now bleeds oil
Old Jul 4, 2011 | 09:26 PM
what next ?
Old Jul 5, 2011 | 01:06 PM
boondocker's Avatar
I'm just getting the rocket all zipped up, I have a TH350 seal kit and a Cliff Ruggles custom HP kit in the mail...once I get the engine and trans complete I'll install into the rebuilt chassis then get the body in order. This is a complete build from scratch using parts from many sources Ebay/Kijiji etc...The intent was a complete a top to bottom learning experience from piston to hubcap (see pix...i know valve covers are reversed).
Old Jul 5, 2011 | 01:19 PM
Red71's Avatar
what type of oil are you using? you definitely want something made for flat tappet cams.
unless it is a roller cam. with all the priming and turning engine over by hand may have
just washed the assembly lube off the lifters. Im not trying to rain on your parade,
just trying help.
some of the better oils are Joe Gibbs, and Brad Penn.
jst my 2 1/2 cents
Old Jul 5, 2011 | 01:30 PM
boondocker's Avatar
I used Shell 5W30, although I didn't turn the crank that much (very small increments) the most common breakin oil in these parts is Lucas. However I will take your advice...thanks.
Old Jul 5, 2011 | 02:05 PM
boondocker's Avatar
I just found a Brad Penn dealer and they sell by the case (x12)...I guess I need to use up the case during the break in?
Old Jul 5, 2011 | 06:24 PM
coppercutlass's Avatar
Chevy budget Olds powered
i ran rotella 15w40 with the lucas zinc additive some of those specialty oils can get expensive i always run rotella with the lucas zinc additive never had any issues
Old Jul 7, 2011 | 10:57 AM
boondocker's Avatar
I filled her up with Brad Penn breakin oil, do I have to change this after breaking in the cam (20-30 min. @2k)?
Old Jul 7, 2011 | 08:53 PM
Red71's Avatar
right on brother. only thing I suggest is to vary the RPM up and down a few hundred during that time.
keep us posted ,wish you the best
Old Jul 8, 2011 | 06:57 PM
i agree with red71 vary the rpms i like to brake mine in between 2k ans 2500 rpm for about 20 minutes and then i drain the oil add new oil and filter and let it idle for about half an hour always works good luck with the new engine
Old Jul 26, 2011 | 06:11 PM
boondocker's Avatar
Have been working on the body and chassis, but managed to get the q jet built. Used Cliff Ruggles HP kit (+jets, metering rods, pull off, idle tubes and e choke), everything installed and adjusted, but need to finish the plumbing. Also started the TH350, new seals, waiting for the Transgo kit.
rodan
Jul 4, 2014 03:02 PM
jaygtx440
Sep 21, 2012 09:07 PM
willj
Oct 17, 2010 04:23 PM
Sam Barrett
Nov 4, 2009 06:46 AM
redvettemike
May 25, 2009 08:42 PM
