New 350 piston
New 350 piston
I am pleased to announce that I have received a verbal commitment on a new Forged 350 piston. Although not carved in stone the specs would be;
4.100" bore
4032 material
.980 pin
1.620 compression distance
8cc D shaped Cup and the most modern ring pack available today, 1.00mm, 1.00mm, 2.00mm all steel ring set.
Price would be in the $600.00 range which would include pistons, pins, clips AND rings. Overall piston weight would be significantly less than all the current pistons available today.
This piston will also fit the 400E as well.
4.100" bore
4032 material
.980 pin
Nice Mark, looks like those will give mid to high 9 to 1 compression on a 350 with early heads. That is a fair price with rings and pins, is that the stock pin size? Too bad the Procomp SBO rods were a limited run and measured all over the place.
I revised the post to reflect pin size.
I really appreciate you taking the time to bring some nice 350 parts to all of us. I read a statement your wrote in another thread saying " You try your best" . I'm sure everyone here knows that.
The extra time you spend trying to get small bock olds parts produced for us SBO guys really shows your commitment to our community.
Thanks for going above and beyond "just trying",,,, also for all your terrific Olds engine builds, the effort put in to help us all here.
Cheers Mark!!!
Put-r-ther,
Eric
Cheers Mark!!!
Put-r-ther,
Eric
This piston will be an upgrade from the speed pro stuff as well as being an additional size for the 350 and 400E.
shamusj
Brakes/Hydraulic Systems
November 17th, 2023 03:47 PM
