Need Experts to Explain
Old Aug 6, 2015 | 04:19 PM
Bennyboy2's Avatar
Cool Need Experts to Explain
Recently purchased 70 Cutlass Supreme . Ok Everything I see says they came with 350 /2 barrel. Mine definitely is a four barrel dual exhaust with a 400 automatic. Any thoughts??
Old Aug 6, 2015 | 04:45 PM
Octania's Avatar
I think many other engine options were available, but not a TH400 behind a 350 engine, so you need to do more detective work on exact casting ID's and whatnot
Old Aug 6, 2015 | 05:08 PM
1970cs's Avatar
Lansing built
In 1970 the supreme had the 350 4bbl. as the standard engine. You could opt out for 350 2bbl. for a credit.
And if you went with the SX option you would receive the 455 2bbl. And W32 option 455 4bbl.
Pat
Old Aug 6, 2015 | 05:21 PM
Bennyboy2's Avatar
Wink Thanks
Time to get my specs on and do a closer exam!
Old Aug 6, 2015 | 05:24 PM
Bennyboy2's Avatar
Thanks for the heads up ! I am just enjoying the Car. Sold my 54 delivery sedan after 3years for building and showing so now just looking to Cruise in style !
Old Aug 7, 2015 | 07:09 AM
Yeah, I think that "everything" that you've been looking at is incorrect. First, the base drivetrain in the 1970 Supreme was the 350 4bbl with three speed column shifted manual. The only automatic factory installed behind the 350 in that car was the TH350. NO 1970 Supremes got a TH400 with a 350 motor from the factory, period. The 350 2bbl was an available option, but not standard equipment. You could also get a 455, and that was the only way to get a factory-installed TH400. Check the VIN-derivative on the engine and trans.
Old Aug 7, 2015 | 03:32 PM
61reoldsman's Avatar
Hey Joe what about the Hydramatic 375 ? Wasn't that in a 400 style transmission body?
Old Aug 7, 2015 | 03:37 PM
It was, but it was never installed in A-bodies.
Old Aug 7, 2015 | 04:24 PM
Diego's Avatar
What is everything you've seen?
Old Aug 7, 2015 | 04:43 PM
Ahh ok then
Old Aug 8, 2015 | 06:38 AM
442Harv's Avatar
I had a 72 VC. It had a 350, with a 375 tran. I thought it was a 400 till I took it out, as it looks like a 400, but has the tail shaft the same size as a 350. Maybe they only used them in VC?
Old Aug 8, 2015 | 07:31 AM
Interesting. I was under the impression they were B/C-body 350 only, but it looks like I was mistaken - the '72 SPECS Guide shows TWO columns for the M40 transmission under "Power Teams":
One column for the big blocks, and another for the SB fullsize models and the SB Vista, so it looks like the SB Vista got the TH375 in '72 (though none of the other A-bodies did).
Old Aug 8, 2015 | 07:49 AM
Octania's Avatar
Yes, a Vista is NOT the same as a Cutlass.
Similar in many ways, but not identical.
Like, trans use...
Old Aug 9, 2015 | 10:19 AM
Like, trans use...
Except from the front doors forward...
The TH375 was used in the VC behind the small block from at least the 1968 model year. My first car was a 68 VC that my parents bought new (after the 63 D88 wagon got t-boned) and I inherited when I got my license. It had a 350/TH375 drivetrain.
Of course, VC also got the bigger back brakes, bigger rear wheel bearings, fully boxed frame, longer wheelbase, and other changes Chris alludes to based on the intended heavier hauling duties this wagon was supposed to handle. Keep in mind that until 1971, the VC was the top-of-the-line wagon for Olds.
Old Aug 13, 2015 | 06:24 PM
Octania's Avatar
"Except from the front doors forward..."
Oh, Joe P., is the engine not forward of the front doors now?
jpc647
Jun 10, 2013 11:48 AM
Octania
Mar 28, 2013 09:19 AM
jensenracing77
Jul 24, 2012 12:17 PM
dmontanagrizzlies
Jun 19, 2009 09:27 AM
jeffs 89 cutlass salon
Nov 5, 2007 05:48 PM
