Nascar 350 dx build 8,000+ rpm
Old November 8th, 2023, 09:01 AM
  #121
HighwayStar 442's Avatar
Not breaking that bottom end.
HighwayStar 442 is offline
Old November 8th, 2023, 09:57 AM
  #122
fleming442's Avatar
You just jinxed yourself, dummy!
fleming442 is offline
Old November 8th, 2023, 10:07 AM
  #123
rickw30's Avatar
Looking F@@@ing awesome !
​​​​​​ Finally getting somewhere.
rickw30 is offline
Old November 8th, 2023, 10:12 AM
  #124
Nah! My builder is my ace in the hole. What Peyton and Nascar done with this block. I am a pussycat.
Old November 8th, 2023, 03:37 PM
  #125
oldsmoboogie's Avatar
Originally Posted by HighwayStar 442
Do you have any pictures? I putting everything I have on here for this one. To document as many blocks that Old's made.
VHT SP404 Engine Metallic Gold Flake
Bore - 3.995
Main bearings - 3.00
Lifter bore - .875
I have the block that 68 post sold. I can get pics up soon.
oldsmoboogie is offline
Old November 10th, 2023, 08:00 AM
  #126
CANADIANOLDS's Avatar
What intake are you going with?
CANADIANOLDS is offline
Old November 10th, 2023, 08:08 AM
  #127
The Victor made for the Battens on small block. NOS
Old November 10th, 2023, 08:10 AM
  #128
rickw30's Avatar
That's a beauty !
rickw30 is offline
Old November 10th, 2023, 08:29 AM
  #129
Originally Posted by rickw30
That's a beauty !
The best is yet to come.
I also found a guy who is building two 17'' x 10'' wheels Smoothie II. Just like the ones I have since 2008. Mine were only 17'' x 8''. Bigger tires for the rear! Shoe horn and a baseball bat to fit.
Old November 10th, 2023, 09:29 AM
  #130
While anything will break under enough force, I will agree that that four bolt setup you are doing makes it so those parts will not be the failure point. I wish there was a way to do 6 bolt mains on these old engines, but I don't think it's possible.
Koda is offline
Old November 10th, 2023, 10:27 AM
  #131
Hi Koda, I say cautiously Normal DX blocks with added 4 bolt mains. And lightweight rotating assembly is more than most here need.
RR block for the big boy drag racers.
Peyton may build a engine block one day. His heads, are him thinking outside the box. Just making the heads wider, to do what you need. He is young. He made a cad drawing of this same HP block his brother has twin turbos on.
Want 6 bolls mains with 6 bolts around cylinder.. Buy a LSX that Warren Johnson help design. That was Oldsmobile enough for me. And one of the ways I was going.
Old November 13th, 2023, 08:19 AM
  #132
Old November 13th, 2023, 08:22 AM
  #133
rickw30's Avatar
Looks beautiful John.
rickw30 is offline
Old November 13th, 2023, 08:31 AM
  #134
Rick, It will look even better in my car! Heads next!
Old November 13th, 2023, 08:35 AM
  #135
66-3X2 442's Avatar
I'm impressed,looks like a killer engine to me.
66-3X2 442 is offline
Old November 13th, 2023, 08:46 AM
  #136
Thanks Mike, And I have You and Rick to thank!!! Car you initially built and Rick's rare HP engine block and heads.
With the work I added. Its a dream come true for Me!
Old November 13th, 2023, 08:49 AM
  #137
rickw30's Avatar
I'm looking forward to you inviting me over for a hell ride
rickw30 is offline
Old November 13th, 2023, 08:51 AM
  #138
Yes! You better be wearing a diaper.
Old November 13th, 2023, 08:56 AM
  #139
rickw30's Avatar
After all these years of just looking at that engine, I'm so excited your getting it done.
A Lot of headaches but it will be worth it.
rickw30 is offline
Old November 13th, 2023, 09:14 AM
  #140
Past owned:
crossboss's Avatar
Amazing and very impressive build! Thanks for sharing.
crossboss is offline
Old November 13th, 2023, 09:25 AM
  #141
Its far from all done. Working on the car to survive this engine.
Old November 13th, 2023, 03:09 PM
  #142
ok, good choice. I haven’t been following along closely. You initially said you were going to make your own intake to fit under the hood ….and your own oil pan .
Old November 13th, 2023, 03:31 PM
  #143
Thanks, I already had it. But did not think it would fit under existing the 2'' cowl. Will make it fit. Oil pan, I just want it to do its job correctly and not leak.
Old November 14th, 2023, 01:39 PM
  #144
Rick, this could have been you.
Old November 14th, 2023, 02:32 PM
  #145
rickw30's Avatar
Don't rub it in John !
I'm just happy it went to good owner who will appreciate her.
I just hope you rub her down as much as I did.
rickw30 is offline
Old November 14th, 2023, 02:34 PM
  #146
rickw30's Avatar
Looks amazing !
rickw30 is offline
Old November 14th, 2023, 02:50 PM
  #147
I promise to ride her hard and put her away wet
Old November 14th, 2023, 03:58 PM
  #148
rickw30's Avatar
Believe me the only ones coming home wet after a blast with that thing is You and your passenger.
rickw30 is offline
Old November 14th, 2023, 04:02 PM
  #149
rickw30's Avatar
When does Bill expect to get it on the Dyno ?
rickw30 is offline
Old November 14th, 2023, 04:08 PM
  #150
Next few weeks I hope.
Old November 16th, 2023, 05:09 PM
  #151
what shifter set up will you be going with? 😁
Old November 16th, 2023, 05:20 PM
  #152
[/QUOTE]
The ones I been using for 34 years.
Old November 16th, 2023, 08:32 PM
  #153
Wow, that’s awesome…I had no idea.
make sure you post a video of you banging through them gears when it’s all done😎
Old November 16th, 2023, 09:23 PM
  #154
Yes, is that before or after I break something on the car. And have to fix??
Old November 16th, 2023, 09:49 PM
  #155
you aren’t gonna break anything with those tires on it…put some sticky’s on , then see what happens
Old November 16th, 2023, 10:56 PM
  #156
I have some wider rim coming next week for the rear. With the biggest tires that will fit. From Chris Coddington, great guy! He had the same wheel from 2008 that are on the car. See how it goes, he want to do 18'' x 12'' rim. Kind of see what happens with the 10'' wide ones. This is my daily driver, I know most of the cops here. I do not want to push to far.
Old November 17th, 2023, 01:41 AM
  #157
well, as far as I know , sticky tires prevent problems with cops because they don’t squeal like a pig and let the whole world know exactly where you are…oh ya, and no smoke
Old November 17th, 2023, 01:47 AM
  #158
rickw30's Avatar
If the rest of your drivetrain isn't up to par with that engine you will definitely be braking stuff hooking up with stickies.
BEWARE !
rickw30 is offline
Old November 17th, 2023, 05:06 AM
  #159
Out of Line, Everytime😉
olds 307 and 403's Avatar
What is your current 2004R situation and a 8.5" rear? This little motor will test the capacity of both, which is awesome!
olds 307 and 403 is offline
Old November 17th, 2023, 07:39 AM
  #160
Continental extreme contact sport 285/40R17 100 W Tires out back on new wheels. Are sticky enough for me. No snow here. Again streetcar. 2004R good till it breaks. Hope to start on the plan to beefing up the frame next week. I have alot of work to do. Have a go to guy now with welder and auto knowledge to help me.
Rear end I am going back and forth S60, Ford 9 or 12 bolt. 8.5 would die for sure. The way I am going Gears Jammer in HighwayStar. Best to sell my well maintain 8.5.
Quick Reply: Nascar 350 dx build 8,000+ rpm
