My 72 442 with 350 and TH400
Old Jul 8, 2012 | 04:14 AM
Brook's Avatar
I have my car in the shop for a body restoration, and thought why not try and get some more Hp out of the anemic stock 180Hp.
I live in College Station, TX and am looking for someone that can help me understand what can be done.
I would like to keep the engine looking as stock as possible, but increasing the Hp to over 300.
I would welcome and appreciate some clear and detailed suggestions. I would like to stay in the $3-5K range to get the work done.
Thanks for your help and you can email me at brooktolman@gmail.com
Old Jul 8, 2012 | 08:19 AM
oldsmobiledave's Avatar
Fyi
You realize ofcourse that your "stock" 180 hp is a NET rating. The gross rating for the same engine in 1971 was 260 hp. Getting your engine to 300 gross hp & keeping it streetable is a very simple task.
Old Jul 8, 2012 | 09:21 AM
Fastback71's Avatar
yeah i dont know about 260. i put my **** on the dyno a couple months ago and was very disappointed. mind you my carb isnt tuned correcty, i have an exhaust leak at the manifold and only single exit exhaust. 130 HP with 223 ft. lbs. of torque
Old Jul 8, 2012 | 09:42 AM
more
With those results I would be doing a compression check & looking at my plugs to see what is up with the engine.....definately way down on power.
Old Jul 8, 2012 | 09:46 AM
Fastback71's Avatar
oldsmobiledave- ive been thinking about my plugs lately because i know inbetween my wanna-be carb tunes im running super rich and the car runs like ****. I probably have some fouled spark plugs from too much fuel. ill pull out a couple and check the gap (.040) and try to clean em off. if theyre too bad ill just replace with standard a/c delco's
Old Jul 8, 2012 | 10:07 AM
Brook's Avatar
Some specifics please
Oldsmobiledave - can you give me some specifics to get 300Hp+. I failed to mention, it does have the dual exhaust.
Appreciate any help you can give me.
raider973
Oct 25, 2014 09:18 AM
88hurstolds
Jan 20, 2012 05:21 PM
TRW
Jan 21, 2011 05:38 AM
ls442
Nov 11, 2010 10:45 PM
deadmanscurve
Mar 12, 2009 03:53 AM
