Motor not running right !!!
Old Sep 13, 2015 | 12:07 AM
  #41
1BOSS83's Avatar
So what happened?
x2
Old Sep 13, 2015 | 03:39 AM
  #42
Rustbucket2's Avatar
Hot wire didn't change a thing. Transmission is not shifting, If you put it in lower gear and shift it up manually, it does act like a car should. My brother is going to talk to a transmission shop about it.
Old Sep 13, 2015 | 04:15 AM
  #43
svnt442's Avatar
Where is the vacuum line for the trans connected on the engine?
Old Sep 13, 2015 | 06:26 AM
  #44
X2 is the modulator connected to manifold vacuum?
Old Sep 13, 2015 | 09:44 AM
  #45
Is plugged in, right behind water neck on intake . only has two nipples at that port.
Old Sep 13, 2015 | 10:28 AM
  #46
svnt442's Avatar
It needs to go to the vacuum port on the base of the carb (non ported).
Old Sep 13, 2015 | 12:13 PM
  #47
olds 307 and 403's Avatar
Out of Line, Everytime😉
Adjust your kick down cable to start. Been awhile since I have played with a TH350, a blown modulator or unhooked line will prevent up shifts correct? Lack of kick down will make it feel doggy at highway speed.
Old Sep 13, 2015 | 12:28 PM
  #48
svnt442's Avatar
It's not like a TV cable, there is no adjustment.
Old Sep 13, 2015 | 09:23 PM
  #49
The newer ones were adjustable.
Old Sep 13, 2015 | 10:43 PM
  #50
svnt442's Avatar
Not in 1973.
Old Sep 14, 2015 | 06:38 AM
  #51
Is it attached directly to gas pedal? I think my 76 was that way. How it heck do you fix it, replace the cable?
Old Sep 14, 2015 | 06:43 AM
  #52
Originally Posted by svnt442
Not in 1973.
Actually, they are. The accelerator pedal end of the cable has a solid steel shaft swaged on the end of the flexible cable. There is a spring clip that slides on this shaft. The spring clip governs when the accelerator pedal tab pulls the cable. The clip can be moved in and out on the shaft to adjust the kickdown point.
SEARCH is your friend, as always...
https://classicoldsmobile.com/forums...cutlass-s.html
Old Mar 31, 2016 | 01:15 PM
  #53
I know it's been a long time, but I pulled the cutlass out of storage today! I was upset with the way it was running so I put it away, and thought I would get back to it some day. well here is a update, thanks to svnt442, my vacuum lines were the problem, moved it to where the diagram showed, now car runs like crazy, big burn outs, transmission shift like it should, lots of power, my brother is on cloud nine. Thanks to everyone that help me along the way, sorry it took so long to get a outcome for all of you. Troy
Old Mar 31, 2016 | 03:20 PM
  #54
svnt442's Avatar
I'm glad it's running top notch now.
Old Apr 2, 2016 | 05:41 AM
  #55
Glad to here. I need to adjust my kick down my 70 like Joe explained.
Carl, uk
Mar 13, 2014 05:43 AM
jpc647
Jun 8, 2013 06:39 PM
StarGeneral
Sep 18, 2012 10:56 AM
84oldsDelta88
May 16, 2011 05:50 AM
Rex
Aug 4, 2010 08:19 PM
