Manifold
Old May 10, 2012 | 08:06 PM
805cut's Avatar
Manifold
How hard is it to install a new manifold on a olds 350? Id imagine it would be pretty easy take the carb off remove all hoses and such, new gaskets and wallah the one i have is pretty beat up, plus a look into the engine wouldnt hurt..
thanks!
Old May 11, 2012 | 06:18 AM
It's very easy, as you mentioned above is all it takes. By the way this particular job does go a lot better with beer, a friend, and the cussing handbook.
The friend is helpful as that manifold is pretty heavy and you need someone to cuss at.
Old May 11, 2012 | 07:05 AM
frankr442's Avatar
One thing to keep in mind is that you are openning up the engine. Cleanliness is next to Godliness. Before you remove the intake, clean all the little corners and pockets where the manifold meets the heads that collect crud. Blow everything off with compressed air if possible. Don't forget to drain some coolant. When cleaning the gasket surface, don't let anything fall into the ports or the valley. Also look up the torque specs and sequence. Pay attention and you'll be fine.
Old May 11, 2012 | 09:20 AM
805cut's Avatar
Hahaha Well the beer gose without saying, i have just the buddy in mind to and i dont need the hand book im a f*#%ing pro! HAHA
Old May 11, 2012 | 09:46 AM
oldsguybry's Avatar
NOVICE car nut
No one beats me in the cussing dept . and it dont take much either !
Old May 11, 2012 | 11:09 AM
805cut's Avatar
Haha id say anyone who has ever spun a wrench is a solid representative of the cussing dept.
SMOKEYMTNKUSTOMS
Oct 12, 2006 12:18 PM
dynamic88builder
Jan 24, 2006 10:52 AM
JONESY
Jan 24, 2006 10:47 AM
JONESY
Aug 10, 2005 04:28 AM
dynamic88builder
Aug 9, 2005 06:45 PM
