M4MC carburetor connection questions
Old Oct 15, 2024 | 07:26 PM
illumined's Avatar
1978 Ninety Eight
After reinstalling the carburetor back onto the engine (403 V8) there were two external springs, one I was able to figure out one of them was the throttle return spring. But I'm at a total loss for the other. I vaguely remember it is connecting the secondary lever to *something*, which makes sense since the secondaries don't seem to open when i simulate wide open throttle. I get the sense I'm missing something very very obvious, but as I'm new at this not everything is as obvious as it should be.
I also wasn't able to find where the AC idle solenoid connected to. I've plugged in everything on the wiring harness except what I believe is the low coolant level sensor. It's too short to reach much but unless I'm missing something obvious (again) there doesn't seem to be anything to connect to.
I didn't take a picture prior because I figured the chassis service manual would show where it goes, but I was unable to find it on both counts. The wiring diagram doesn't even show the AC idle solenoid at all.
By the way I did circle back to the fuel filter situation from before, as it turns out it did have a filter in the inlet, and it had an external inline filter. I have no idea why, I replaced the rubber fuel line and I'm not seeing a need to put back on another external fuel filter.
Old Oct 15, 2024 | 08:07 PM
That is 100% normal as the QJet secondaries are a “demand” system and don’t open with no load (as in revving while in park or neutral).
Old Oct 15, 2024 | 08:56 PM
illumined's Avatar
1978 Ninety Eight
Ok that makes sense. Then the spring must be some kind of return spring for them?
BTW I also belatedly realized the connection I thought was for the coolant level sensor as it turned out was for the idle solenoid. One mystery down.
Old Oct 15, 2024 | 08:57 PM
Sugar Bear's Avatar
Are the springs similar to each other, does one fit inside the other? If yes, they may both be throttle return springs.
Old Oct 15, 2024 | 09:00 PM
illumined's Avatar
1978 Ninety Eight
I admit that thought never occurred to me, I will have to try that when I work on it again this weekend. Thank you.
Old Oct 16, 2024 | 04:57 PM
There are two return springs for redundancy. One goes inside the other.
Old Oct 16, 2024 | 05:53 PM
Sugar Bear's Avatar
You can say that again...
ub2693v
Mar 8, 2024 01:43 PM
Falkon
Apr 15, 2023 07:59 PM
jpc647
Nov 2, 2014 03:40 PM
Cutdawg78
Apr 23, 2012 06:13 PM
RussTad
May 28, 2008 03:16 PM
