lower radiator hose on 330ci
Old Dec 26, 2008 | 07:56 AM
jdanieljones's Avatar
I try to give back when I can.
Lower radiator hoses on 330ci engines aren't being made (that I could find) and the flexible ones get eaten by the fan belt.
My local NAPA guy prides himself on finding hoses that fit and here's a find.
NAPA ECR 8100 fit's pretty darn perfect. You cut it off at the bend leaving as much hose as you can and stretch it just a bit. Other than that… just like factory.
Old Dec 26, 2008 | 09:05 AM
That's good info, but what year are you using it on? Keep in mind that 64s are different from the 65-67 cars due to the one-year-only water pump with the LH inlet.
Old Dec 26, 2008 | 06:47 PM
ent72olds's Avatar
Registered Luser
I just recently replaced the lower on my '67 330. I have to do the w/p tomorrow. I will check to see if the sticker is still on it with part #. If so I will post.
Old Dec 27, 2008 | 06:07 PM
ent72olds's Avatar
Registered Luser
Have a gates part # to the lower rad hose on a '67 330. Did need some minor trimming on rad side to prevent riding on inner frame rail. Part # is gates 20595. Nice fit.
Old Dec 27, 2008 | 06:14 PM
rocketraider's Avatar
Oldsdruid
Good research. Wish every parts man would take the initiative like that.
Ames Performance (Pontiac vendor) has had notes on parts for years "fit and function are correct", when they'd found a good substitute for something no longer made and not cost effective to reproduce.
Makes me think I need to go buy up some replacement stock before Fusick discontinues more of their early 60s big car stuff.
Old Dec 28, 2008 | 01:55 PM
Warhead's Avatar
GOOD STUFF!
I will emblazen that number on my forehead.
THANKYOU!!!
Jim
jjokrm
Dec 27, 2012 08:30 AM
belairbob
Sep 27, 2012 07:09 PM
matviar
Apr 9, 2012 12:56 PM
radioburningchrome
Oct 7, 2009 05:11 PM
harleyrules
Nov 25, 2007 07:22 PM
