Low oil pressure after engine rebuild
Old Jun 21, 2021 | 04:15 AM
freloncharlo's Avatar
Hello everyone,
I introduced myself several month ago, with mine 1972 cutlass 442 clone, with its 350 Rocket, from France !
Here is my issu, the oil pressure was very low 5psi at idle, and 2à while accelerate.
The low engine was very bad looking, si I decided to change many parts (Crankshaft, main bearing, etc)
But now, after all that work done, the first start looks good, around 45-50PSi at idle, but when it is getting hot, the tach shows 15psi at idle, and around 45 when i accelerate.
My question is : Do you think everything running good when the gauge shows me 15psi at idle ? Is it normal on these 350 rocket ?
Thank you very much for your help
Old Jun 21, 2021 | 04:23 AM
Oldsmaniac's Avatar
Yes that is very good oil pressure.
Old Jun 21, 2021 | 05:15 AM
10-15 at idle is not too low ?
Old Jun 21, 2021 | 05:21 AM
I agree with Oldsmaniac, that is good oil pressure. What brand gauge are you using?
Old Jun 21, 2021 | 05:24 AM
Thanks for your opinion, to be honest I am not really sure because I don't work on it, you want to know if it's an electronic one or a mecanic one ?
Old Jun 21, 2021 | 05:28 AM
If your mechanic just relayed those oil pressure numbers to you ask him what kind of gauge he's using.
olds 307 and 403's Avatar
Out of Line, Everytime😉
Yeah, especially if that is like 700 rpm in gear, that is acceptable. Did you do an oil change shortly after the initial start up? Always a good idea, incase dirt and metal debris was missed during the rebuild. Also what weight of engine oil are you using?
Old Jun 21, 2021 | 05:42 AM
Okay mate, he told me that is an electronic one, and he checked the gauge it seems to be good
Old Jun 21, 2021 | 05:47 AM
At idle, it run around 800Rpm, I bring the car at home this afternoon, the oil is all new, and I will change this one in thousand miles. For now, the oil is 20W50
Old Jun 21, 2021 | 06:06 AM
joesw31's Avatar
15psi with 20/50 oil in my opinion is low. I would expect that oil pressure out of a high mileage engine. Did you use a new oil pump? You can have your mechanic shim your oil pump to increase the oil pressure.
Old Jun 21, 2021 | 06:18 AM
The oil pump is brand new and it's an heavy duty one, the pump is already on the high pressure mode
Coastie
Apr 13, 2021 05:38 PM
Ebonycape
Dec 2, 2018 07:42 PM
Bseward78
Jul 9, 2017 03:55 AM
jtriggy
Aug 23, 2010 08:53 PM
tim72
Apr 1, 2010 06:27 PM
