Installing the intake
Did I read on a previous thread that when installing the intake on a 350 that to replace the rubber end gaskets with a bead of silicone. I am in the process of putting my 350 together and am needing to know if this is so. Thanks Larry
Maybe I'm just old fashioned, but I have never used RTV for sealing the ends of an intake. I have always used the gaskets and never had issues. I used them just a couple weeks ago when I put the top end of my 330 back together. Cleanliness is next to godliness when it comes to assembling engines so when it comes time to put the intake on, clean the block rails with sandpaper until it is bright. Use a towel to keep debris out of the engine and then vacuum the valley out afterwards to make sure all of those little abrasive particles are not left inside the engine. Then use brake cleaner on a towel to clean the lifter valley, the block, and intake mating surfaces. When you are ready to place the intake, Put a dab of RTV in the corners where the gasket fits between the block and head. Make sure the gasket fits into the crevice without twisting or curling. Set the intake in place and tighten. Just the way I do things.
Nice and clean!
Installed! No leaks yet.
Nice and clean!
cjsdad may have a point. The dry rubber may hold better than trying the slippery silicone under it. I used silicone and the rubber gaskets when I installed my intake. The gaskets kept squeezing out, nothing i did would keep them in place. Finally I decided to use some of the urethane windshield adhesive I had, and it seems to have worked great. A urethane rubber gasket in a tube. Time will tell when I actually get the motor running. I dont really like RTV, as oil seems to eventually break it down. Back in the early 70's we didnt have RTV. The guys who taught me, told me to use 3M trim adhesive, on ALL gaskets. I guess it worked ok, LOL I cant really remember. Not sure if the intake gaskets squeezed out on that motor, 67 E block, but then I dont think I ever checked or thought about that. It was my first engine build, so I was learning..... It ran great when i finished, leaks? who knows.
I put a light coat weather strip adhesive on the engine side and the bottom of the rubber end seals, let it skim over and then stick them on. The weather strip cement is a contact type of adhesive and will hold them in place. I also do the same with valve cover gaskets by gluing them to the valve cover.
Nice and clean!
Nice and clean!
The Right Stuff. Let it cure and trim it then. I dont know why the gasket companies even waste their time and resources manufacturing the rubber deck seals. They aren't engineered properly and never, NEVER work. They are too thick.
You found out exactly why silicone sealer should be used in the corners only when installing the rubber end seals.
svnt442
July 17th, 2011 04:43 PM
