Installation fan controller
Hello guys, what is the ideal way to install the fan controller (see picture)? Stick it through the radiator or put it in the hose? When I stick it through the radiator, does it measure the right way because of the airstream while driving? When I stick it in the hose i´m afraid to damage it, because it is filled with gas?
Thank you for your tech tips
Daniel
Daniel
I've used that style controller before. The bulb is supposed to be in the coolant flow in the radiator hose. There is supposed to be a rubber "wedge" that sits on the hose barb on the radiator and has a groove for the capillary tube so you don't crush it when you tighten the hose clamp.
Bee Saint Louis
July 5th, 2019 08:58 PM
Dan Wirth
December 2nd, 2011 12:55 PM
