Hydraulic Roller Cam for a 330
Old Jul 16, 2013 | 08:27 PM
rcdynamic88's Avatar
Are the camshafts listed for the 350 Olds OK to use in the 330? You folks here on ClassicOldsmobile clued me in to the intake manifold information. Now I'm wondering if the same is true for the camshaft offerings out there. Will the retro-fit hyd roller cams listed for the 350 Olds be good to go in a 330? Can anyone confirm the comp ratio of 10.25:1 for a 1965 330 315 HP? Should I be looking at a head swap to bring that ratio down? What heads would be a good choice? Anyone put E-Brock heads on a 330 yet?
Old Jul 16, 2013 | 08:35 PM
krooser's Avatar
Hot Rod Has Been
The 330 ('64 to '67) has a 39 degree lifter bank angle... the 350's are 45 degree. The cams do not interchange.
Those 330 heads you are pretty good... why lower the compression ratio? Compression equals HP. The 10.25 is with a stock steel shim head gasket... newer styles are thicker so you will likely lose 1/4 point or more.
You'll get many different cam recommendations here... I got my 330 cam from www.camcraftcams.com .
Old Jul 17, 2013 | 06:26 AM
cutlassefi's Avatar
Originally Posted by krooser
The 330 ('64 to '67) has a 39 degree lifter bank angle... the 350's are 45 degree. You have that backwards. The cams do not interchange.
However aren't the later 330's a 39 degree lifter angle? Anyone?
Right now there are only a couple of cam companies that have 45 degree cores for a roller, Bullet and OPP, and they're expensive.
Old Jul 17, 2013 | 07:53 AM
oldsmobiledave's Avatar
Correction
This information although well intended is wrong. Didn't you mean to type that the early engines have the 45 deg bank angle while the later engines are 39 deg?.
Further, only the 64-66 330 uses the early 45 deg bank angle. The 1967 # 4 headed 330 shares the 39 deg bank angle with the later built 350 & other Olds small blocks.
Old Jul 17, 2013 | 08:44 AM
krooser's Avatar
Hot Rod Has Been
Alzheimers.... sorry.
Old Jul 17, 2013 | 08:45 AM
krooser's Avatar
Hot Rod Has Been
Yeah I goofed... my mistake. But my '67 330 is a 45 degree... I'm no Olds expert but the three 330's I explored all were 45 degree engines.
Old Jul 17, 2013 | 04:21 PM
jag1886's Avatar
Most of the cam companies will grind you the correct cam, as long as you want it bad enough.
Old Jul 17, 2013 | 04:37 PM
more
On ROP I remember discussions of early 330s being 45 deg bank angle engines. I have owned three #4 head 1967 330s & they were all 39 deg bank angle engines.
Old Jul 17, 2013 | 09:47 PM
krooser's Avatar
Hot Rod Has Been
My '67 #4 headed project motor is a 45 degree... and the two others I have seen in the last year were also 45's....
Most cam grinders don't carry the 45 degree cam blanks but they can be bought from CWC. But I doubt you'd get a roller from anyone.
Old Jul 18, 2013 | 05:01 AM
cutlassefi's Avatar
Uhh, I think I already said OPP and Bullet have ROLLER cores. Alzheimer's again or you going blind as well? Lol.
Hope your today is better than your yesterday!
smietana
Nov 3, 2013 12:07 PM
Scott Hamel
Aug 16, 2013 07:46 AM
442garage
Aug 9, 2013 07:13 AM
fly1
Dec 8, 2010 07:07 PM
442garage
Oct 20, 2008 10:25 AM
