How to produce 500 hp
Old December 27th, 2013, 02:06 AM
Oldskool84's Avatar
72' 350 5.7 cutlass 'S' ... What combo of aftermarket parts would make 500hp yet still be streetable?
Oldskool84 is offline
Old December 27th, 2013, 03:09 AM
captjim's Avatar
None, unless you put a blower or turbo on it.
captjim is offline
Old December 27th, 2013, 03:46 AM
boese1978's Avatar
I'll be happy to make 380 with my 68 350 bored, stroked, roller set up with ProComp heads.
boese1978 is offline
Old December 27th, 2013, 03:52 AM
I wouldn't say that.
He could install the Bolt-on 500hp LS motor, bolt-on motor mounts, bolt-on exhaust, bolt-on transmission, bolt-on driveshaft, bolt-on rear end, bolt-on fuel injection, bolt-on Impala fuel tank and pump, bolt-on aluminum radiator, and a few other bolt-on parts I've probably left out.
Of course, it all depends on your definition of "streetable," and of whether you include any machine work in that package.
With machine work to produce a high-RPM, high-compression Olds engine, it's a different story.
MDchanic is offline
Old December 27th, 2013, 04:55 AM
jensenracing77's Avatar
Your first step is to find a 455. Are you listening to Chevy guys that toss around HP figures to much? Oldsmobile engine like to produce torque. Yes, you need some HP also but torque moves mass. The nice thing about Oldsmobile engines is that you don't have to run the guts out of it to make good power.
jensenracing77 is offline
Old December 27th, 2013, 07:06 AM
455man's Avatar
With a small block I think pushing for 425hp would be more doable. A lot of people think they are pushing 400 or 500 hp but they are not.
455man is offline
Old December 27th, 2013, 07:32 AM
PHR built a streetable 455 that produced 514 HP and 540 ft-lbs for their 1965 Cutlass. Here's the build article:
http://www.popularhotrodding.com/tec...s_project_car/
joe_padavano is offline
Old December 27th, 2013, 07:58 AM
380 Racer's Avatar
Sigh.........I guess #1 is just how deep is your pocket book? 500 HP......what are you planning to do with it? No matter if it's a BB or SB 500 HP should be able to result in a low11 or high 10 sec ride. This all depends on how your car is set up track conditions. Plan on blowing the rear tires off on the street.
Don't plan on doing it cheaply unless you are going to build it yearly. Spend money on the good stuff or you will be doing it again.
380 Racer is offline
Old December 27th, 2013, 08:01 AM
I stand corrected.
That build used clean-up machine work only.
Of course, every part that bolts on to the engine was replaced, except the crank.
Impressive.
MDchanic is offline
Old December 27th, 2013, 08:24 AM
^^^ This
As noted, if you REALLY have 500 HP and intend to use it, (as opposed to simply bragging about dyno sheets) you will need to upgrade everything else on the car. Trans, driveshaft, rear axle, suspension, tires, fuel system, etc, etc.
Old December 27th, 2013, 08:38 AM
cutlassefi's Avatar
Originally Posted by MDchanic
Impressive.
Sorry but I'm not impressed. Read the whole article, 514hp/540tq from a .030 over 455 with fully ported heads and intake, really?
Plus their math doesn't jive. They state a 10.44:1 compression ratio. I get 11.15:1 with those 5cc SRP pistons, a .005 deck as stated, a .040 gasket and the stock 77cc combustion chambers.
Take it for what it's worth.
cutlassefi is online now
Old December 27th, 2013, 08:39 AM
Kennybill's Avatar
For a "street" car I too would build a 455 for torque and a pump gas engine. Then worry about your weakest link. You will find it if you don't plan ahead. Jmo, Ken
Kennybill is offline
Old December 27th, 2013, 11:17 AM
Oldskool84's Avatar
Ok so lets talk TQ, how can i get the most out of my 72 cutlass S(350 5.7)??
Old December 27th, 2013, 12:10 PM
cutlassefi's Avatar
Forced induction of some sort.
Old December 27th, 2013, 12:11 PM
455man's Avatar
Again it all depends on money. You could stroke it out, bore it, put aluminum heads on it, roller cam, headers, low gear, high stall. Do you plan on running power brakes? That can limit the size of the cam. Budget can limit the horsepower/tq. How often will you be racing this car and how often will you be driving it on the streets? Are you ok with running 91 or 93 octane in it? Right now it's probably a 87 octane motor.
455man is offline
Old December 27th, 2013, 12:29 PM
Oldskool84's Avatar
1. I dont race , i just show my A$$ at a stoplight occasionally(usually when a honda w/ an obscenely loud muffler and nothing behind it pulls up lol!)
2. Already has power brakes, headers, and only runs on premium.
3. Been thinking about doing comp cam retrofit roller cam and edelbrock rpm performer heads.
4. Honestly dont know much about low gear high stall , plz enlighten me.
5. Car was daily driver but has been parked until i get a better understanding of aftermarket parts compatibility. As well as a better overall understanding of what ive got( previous owner(s) did most of the mods and i have to figure out what they did wrong :/ ).
6. Im a Noob so this entire year has been full of growing pains as well as alot of financial losses.
Old December 27th, 2013, 01:01 PM
jfb
jfb's Avatar
make sure the whole combo of the car can handle it first of all. I would shoot for at least 11.5 to 1 compression and 57 to 6000 rpm plus a good 455 at least 30 over. this will get you close to 500 at the flywheel or 400 at the wheels or just use nitrous when wanted with cheaper upgrades and not a huge shot either.
jfb is offline
Old December 27th, 2013, 01:14 PM
455man's Avatar
Do you have an RPM gauge? When you spin the tires do you leave one mark or two?
Lower gears is referring to the gears in the rear end. Higher gears give you a lot of top end speed but are very slow at red lights. Low gears makes it rev very high on the highway.
High stall is referring to the stall converter speed in the transmission. Most stock ones engage at about 1800. A higher stall would throw you back in the seat more...assuming you did not lose traction.
To outrun a honda at a red light you dont need 500hp. A properly set up 350 would run pretty good. Get a timing light. A gear change with a positrack would probably be enough to out run most honda's on the streets.
Also lots of reading on this site will increase your knowledge.
455man is offline
Old December 27th, 2013, 01:22 PM
Oldskool84's Avatar
Tbh im not quite ready to step up to NOS but thx for the input
Old December 27th, 2013, 01:32 PM
Oldskool84's Avatar
I do have an rpm gauge but ive never actually attempted a burnout. I dont have any issues outrunning hondas lol. I was using that as an example of how much i race(or dont race depending on your perspective). Thx for the tip on the positrack tho, i'll look into that.
Old December 27th, 2013, 01:53 PM
captjim's Avatar
Nobody like the Olds 350 more than I do, but for this application I gotta agree with Joe, a 9 to 1 468 that makes 300 HP and 500 Ft/Lbs is perfect.
captjim is offline
Old December 27th, 2013, 04:08 PM
Oldskool84's Avatar
468??
Old December 27th, 2013, 04:19 PM
380 Racer's Avatar
[QUOTE=Oldskool84;632952]I do have an rpm gauge but ive never actually attempted a burnout. QUOTE]
LMAO..........you got to be kidding!!!! And you think you need 500 HP?
Old December 27th, 2013, 04:33 PM
Oldskool84's Avatar
Yes i kno its ridiculous, i just want something respectable i guess. Btw i never attempted a burnout bc i dont wanna brake anything. This car has been a big enough pain in my *** and wallet without doing stupid stuff. If i had any sense at all id just get rid of it , but its just too damn sexy. So ... Here i am asking u gentleman for advice in hopes that i could convince myself to keep my POS car. Sigh... So long story short im just trying to learn how to tune what ive and go from there.
Old December 27th, 2013, 04:47 PM
Mr Nick's Avatar
The car is a pain in the *** and wallet, but you want to spend money to make more power and possibly break stuff?
My thoughts based on your posts in this thread:
1) you don't need 500hp, and (don't take this the wrong way) if you had 500hp I don't think you'd use it.
2) you need many other upgrades to support a 500hp engine ($$$)
3) 500hp, why that number anyway?
4) what's the hang up with Hondas?
5) the portion of your quote that I put in bold, I'm glad you said that. That is where you need to focus. Spend smart money on what you have and slowly turn the car into what you want it to be. If you're set on a nice rebuilt engine, then get what you currently have tuned and running as best as possible, while you build a new engine to replace it with. This way you can enjoy the car while building the engine.
And for Pete's sake, do a burn out!!!! A successful burnout will put a smile on your face and rejuvenate your passion for the car/pos.
Mr Nick is offline
Old December 27th, 2013, 04:52 PM
captjim's Avatar
468??
A 455 bored .060 is a 468. Several companies make pistons for it.
captjim is offline
Old December 27th, 2013, 04:58 PM
Oldskool84's Avatar
Nice. Good to know if i ever come across a 455
Old December 27th, 2013, 05:05 PM
Oldskool84's Avatar
Yup, sounds like good advice.
I just ordered books by Bill trovato & david vizard to educate myself. Hopefully in a couple of months I'll have a video to post of me doing that burnout lol.
Old December 27th, 2013, 05:45 PM
Where are you located? I have a boat load of 455s in Indiana.
Old December 27th, 2013, 06:09 PM
Bernhard's Avatar
How about a 350 built for NOS, 350hp 350 and a 150 shot of NOS.
You would have to learn how to use and tune for NOS.
Bernhard is offline
Old December 27th, 2013, 06:22 PM
  #31
Oldskool84's Avatar
Im a soldier stationed in hawaii (car is here as well) but im from Fla. I guess ill have to keep that in mind for when i go back stateside in a couple years.
Old December 28th, 2013, 06:45 AM
  #32
cutlassefi's Avatar
make sure the whole combo of the car can handle it first of all. I would shoot for at least 11.5 to 1 compression and 57 to 6000 rpm plus a good 455 at least 30 over. this will get you close to 500 at the flywheel or 400 at the wheels.
Lots of other good posts here except this. Don't do this.
Old December 28th, 2013, 01:44 PM
  #33
Oldskool84's Avatar
Im stationed on wheeler aaf (across the street from schofield). Honestly bro if you could just help me find a shop that could get my 350 running smooth I'd be happy with that for now. However, i am very interested in finding a working 455, whether it be on island or in fla ,so if ANYBODY on this thread knows of one plz shoot me the link or PM me the details. Thx
Old December 28th, 2013, 01:48 PM
  #34
Oldskool84's Avatar
Hey man if u dont mind me asking, what part of indiana are u located? Im asking so i can start searching craigslist for a solid running 455 in that area.
Old December 28th, 2013, 02:01 PM
  #35
agpilot442's Avatar
I saw this350 build sevral months ago it seems reasonable not 500 hp
I like 455s and all the torque you get myself.
http://www.powerblocktv.com/episodes...-for-new-power
agpilot442 is offline
Old December 28th, 2013, 02:34 PM
  #36
Just off of I-70 an hour west of Indy. All my 455s are apart but I have several of them that could be built.
Old December 28th, 2013, 02:49 PM
  #37
Oldskool84's Avatar
Yea that was pretty nice, and close to what i was thinking of doing to my 350 if i couldnt find a 455
Old December 28th, 2013, 03:24 PM
  #38
Oldskool84's Avatar
Do you have a youtube channel or website showing your work?
442driver
January 16th, 2008 06:38 PM
Nailhead 88
January 9th, 2008 08:23 PM
jd75
December 28th, 2007 04:04 PM
68fastwilliams
April 30th, 2007 11:33 AM
Joe
October 9th, 2005 07:42 AM
Quick Reply: How to produce 500 hp
