How to Clean out a Rad, without running engine Help
Hello all. Need some help trying to clean out my rad. As many of you know , the car has been sitting and from that, i noticed inside the rad I have what looks like white calcium build up. The fluid levels probably dropped about 2 3 inches and whatever is exposed at the top has the white stuff on it.
Im a while away from starting my engine and all the possibilities Ive read up on, they make you run the engine to clean out the rad.
How can I clean it out without damaging any further and without starting the engine and getting all that crap inaide the block? ( I mean i cant even start the engine anyways, so thats out of the queation anyways.)
Any info would be greatly appreciated. Thanks in advance.
Jesse
Jesse
Be aware that vinegar can attack aluminum. Here's a good thread with a few additional options:
https://www.jalopyjournal.com/forum/...-flush.353511/
Your best bet is to remove the radiator and have it boiled out by a shop like Joe mentioned.
cts-v
January 10th, 2009 06:20 PM
