HOLY CRAP! (& carb update)
![Exclamation](https://classicoldsmobile.com/forums/images/icons/icon4.gif)
So I go in search of my Quadrajet's number (it just says "8115" BTW, as you can see in the picture) and I find that my air cleaner housing has become a moat!
WHAT THE HELL IS THIS GUNK?!? I know it can't be good, that's for sure. It's all around the bottom tray there, but the air cleaner lid has spray/droplets on it just above where the tube with the yellow twist-tie on it enters.
[I took a picture of that tube in its entirety as well.]
The pictures are color-correct, too. It's a kind of amber/root beer color and it smells like fuel. It wasn't there even a week ago (when I had the carb looked at) so... HELP!
Drew
![](https://classicoldsmobile.com/forums/members/auto_editor-albums-1989+olds+custom+cruiser-picture4847-drivers-side-carb-only-has-number.jpg)
![](https://classicoldsmobile.com/forums/members/auto_editor-albums-1989+olds+custom+cruiser-picture4848-air-cleaner-swamp-drivers-side.jpg)
![](https://classicoldsmobile.com/forums/members/auto_editor-albums-1989+olds+custom+cruiser-picture4849-air-cleaner-swamp-passengers-side.jpg)
![](https://classicoldsmobile.com/forums/members/auto_editor-albums-1989+olds+custom+cruiser-picture4850-air-cleaner-swamp.jpg)
![](https://classicoldsmobile.com/forums/members/auto_editor-albums-1989+olds+custom+cruiser-picture4851-air-cleaner-swamp-drivers-side-where-air-intake-enters.jpg)
![](https://classicoldsmobile.com/forums/members/auto_editor-albums-1989+olds+custom+cruiser-picture4852-drivers-side-tube-enters-air-cleaner.jpg)
Drew
![](https://classicoldsmobile.com/forums/members/auto_editor-albums-1989+olds+custom+cruiser-picture4853-air-cleaner-cover-drivers-side.jpg)
Drew
Drew
I think the yellow gunk its condensed water wapors from the crankcase ventilation.
Stanley
what does your oil look like and what about the tube going into the valve cover first thing popped into my head was head gasket blow by. Do you put oil additives in it? The breather tube at the valve cover looks like the same shade on the out side
Looks like your gasket is leaking on your rebuit carb. Paper number is usually a rebuilders reference.
I'd tighten all the screws in a criss-cross pattern, put some rags around the base, and use a can of carb cleaner on the carb, mopping-up any puddles. That should let you see if the carb's leaking.
As far as the 'blow-by', I've ony had it happen with oil from the cheap oil-change places. [I think it's re-cycled!]
Get some good oil, with zinc, and see if it continues!
It does look like a blow-by problem , but it is very common for the PCV passage under the carb. to get plugged up causing excessive blow-by . When you pull the carb. it will be very easy to see . GOOD LUCK ,TOM
Check the oil level and see where it is. IF above full, there is a big problem.
Drain it and see what it looks like. Look for water/coolant.
If all black but very thin and smells like raw gas, the fuel pump diaphragm may have ruptured.
My mom's old 307 did the later and the oil was thin enough to be sucked into the air cleaner.
![Embarrassment](https://classicoldsmobile.com/forums/images/smilies/redface.gif)
Drew
![](https://classicoldsmobile.com/forums/members/auto_editor-albums-1989+olds+custom+cruiser-picture4894-angie-aircleanerafter.jpg)
I then warmed her up and went for a drive, then unscrewed the air filter cap to find a little white/tan froth that had sprayed into the filter housing from the tube "system" I just replaced.
SO, here's where I get stupid (despite a factory service manual): After doing all of the work outlined above to the "PCV system", I still have a shiny new "PVC Filter" without a home. It must be on another "line" as it certainly didn't go anywhere between the valve cover and the air cleaner assembly as THAT has all been redone.
It's got into-rubber-tube-style ends (one larger than the other), so I'm sure it just plugs in-line in between some tube or other, but as EVERYTHING under the hood looks like a rubber tube (and NONE of the components are shiny silver anymore) and I'm not going fishing, perhaps you could point it out to me.
Oh, and the Crankcase Air Filter I replaced weighed like five pounds and was FULL of oil, sludge and muck. If a 169k-mile engine like hers is, well, "supposed to" isn't the right wording, but could be EXPECTED to "froth" a bit, then it is what it is. But I'm trying to eke every mile I can out of this motor before it goes, so if there's something else (inexpensive/easy) that should be attended to, please let me know.
[Now I'm off to beg Aceshigh to let me "Rent-to-Own" his sweet setup...]
![Big Grin](https://classicoldsmobile.com/forums/images/smilies/biggrin.gif)
bill
michigan type weather ( cold/warm temperature cycles )
coupled with short trip driving, can lead to this build up.
its water vapor mixed with oil vapor. as long as youre only finding this stuff in the air cleaner, you should be ok.
just wipe it up when you check your air filter
For a quick / easy check , pull the PCV out of the valve cover with the engine running and make sure you have a good vacuum at the valve . If not the crank case will build pressure and create the excess blow-by and moisture.
[Once I clear all the snow off the car, of course...]
Thanks!
Drew
The Parts place has the PCV elbow for 68-72 Cutlass 350 - part # EN4845T for $6.
I bought one for my '72, did not need it, so I used it on my '86 Cutlass as it was torn like yours. Was a tight fit but I think it was supposed to. I bet it would work on your wagon, too.
Hope you find the sludge source. Is the coolant dropping on its own?
I still think something else is afoot.
Make sure your PCV line is in good working order with no leaks. It should run from the PCV valve in the opposite valve cover from the vent line and filter spewing gunk to the base of the carb. At the age of your vehicle and miles that you've acrued you will have a certain amount of blowby. As the other folks expressed, check your oil to ensure its not the same color of the sludge in your breather. If its black no worries, but change it regularly. Good luck!
Many thanks to all for their help with this! It's just too bad that ALL problems aren't this easy to solve...
Drew
