Holley carb question
Old Jan 19, 2009 | 12:24 AM
Wasted's Avatar
I have a Holley Street Avenger 670cfm that I got used. I was wondering what goes into the top hole in the picture? Im pretty sure that a mixture screw gose in the bottom one, is this correct?
The two holes are on the drivers side behind where the throttle hooks up.
Old Jan 19, 2009 | 10:19 AM
So this is the secondary side (back) metering block? Are you sure these holes are even drilled out, or just blanked? The bottom hole would be for the idle mixture screw, and some Holley carbs do have four hole idle circuits, but that's pretty rare. The upper hole appears to be blanked off as well. On some carbs designed for supercharged applications there is a hose fitting here on the metering block to provide a reference pressure to the power valve.
Old Jan 19, 2009 | 05:02 PM
Wasted's Avatar
Now that I look at it closer the top one dose look like a blank. This carb has three idle mixture screws in it already.Is this normal or dose it mean it should have four?
Old Jan 19, 2009 | 05:47 PM
It should have either two or four, depending on how the carb is configured. Sounds like you need another one.
Old Jan 19, 2009 | 07:53 PM
Wasted's Avatar
Alright thank you Joe.
hawks70
Jun 17, 2013 10:45 PM
fmay50
Dec 9, 2009 02:54 PM
delta881972
Jan 24, 2009 05:54 AM
