Hide Idle
Old May 2, 2013 | 12:19 PM
my71olds's Avatar
Hide Idle
We have a 350 olds that had the heads rebuilt and then we installed back with all new gaskets. The carb and timing was not changed just put back on the engine. We just started it up and checking for any leaks. Need to replace one heater hose and install new thermostat and gasket. We installed new plugs, PVC, and fuel filter. When running it after this we noticed the idle being high. What things do we need to check?
Old May 2, 2013 | 12:58 PM
Is the choke releasing when it's warmed up? If you had the distributor out, I assure you the timing changed. Why not go thru it and double check your tune up specs.
Old May 2, 2013 | 03:23 PM
DoubleV's Avatar
In addition to the above, I would check for vacuum leaks.
Old May 2, 2013 | 03:58 PM
Rickman48's Avatar
X2 on the vacuum leaks!!
Old May 5, 2013 | 05:49 AM
my71olds's Avatar
would the vacuum leaks cause the car to be really loud? We are going to check timing and make sure to original specs. Thanks
Old May 5, 2013 | 05:57 AM
I don't understand the "really loud" question?
Old May 5, 2013 | 06:30 AM
I'd check timing first and then vacuum leaks, since we know the distributor has been moved.
RAMBOW
Jan 9, 2018 01:51 PM
s i 442
Aug 12, 2013 06:38 AM
Seff
Sep 20, 2012 04:46 PM
73rocketship
Jul 6, 2012 06:45 AM
skryla
Dec 13, 2010 11:58 AM
