Where to hide a 6530 MSD Box in a 72 442 with A/C
Old Dec 12, 2010 | 07:16 AM
skryla's Avatar
Hey Guys,
I'm about to hit the garage and wire up the 6530 MSD box. Any suggestions where to hide it? I will still need access to plug into the computer.
Any tach issues I should anticipate. The directions say to hook it up to the gray wire.
Any recommendations, suggestions, comments would be appreciated.
Old Dec 12, 2010 | 07:24 AM
Oldsguy's Avatar
Past Administrator
Is there room under the dash near the center of the firewall? Can't visualize that area but realize there is not a lot of room because of AC. Otherwise, on the outside of the firewall just about any place you choose will be noticed except maybe below the AC hump between the inner and outer fenders, that would be a tight place for sure.
Old Dec 12, 2010 | 06:48 PM
skryla's Avatar
I'm thinking I want to keep it inside if I can.
Has anyone used the stock tach hooked to the gray wire? Did it work or do I need the adapter?
Old Dec 12, 2010 | 09:35 PM
fizzy55's Avatar
i've put a few 6AL's on the firewall behind the fender.just remove the inner fender to get to it .it will be out of the elements and you won't see it unless you really look for it.
Old Dec 13, 2010 | 11:10 AM
I have mine mounted to the radiator support, opposite where the battery goes. Been there for 16 years with no problems. I did have to slightly lengthen the wires leading to the pick-up coil and ignition coil.
Old Dec 13, 2010 | 11:58 AM
skryla's Avatar
Driver or passender's side?
RAMBOW
Jan 9, 2018 01:51 PM
s i 442
Aug 12, 2013 06:38 AM
f-85
Aug 9, 2013 09:22 AM
my71olds
May 5, 2013 06:30 AM
442_Mustang
Nov 4, 2009 07:26 PM
