Help With Cam Selection
Old Sep 11, 2011 | 10:21 AM
78cutlass's Avatar
78cutlass
Need some advice on a good camshaft for my Olds:
'78 Cutlass Supreme 2D
'69 Olds 355, #5's, 9.8:1 CR (fresh quality rebuild)
'70 Olds Qjet carb #7040250 (Sparky redo)
built 700R4 auto OD trans w/2500 stall
8.5 posi rear w/373's
The car is used for cruising & street light to street fun. It doesn't have AC yet, but it will in the future, since I live in S. FLA. I was thinking about Edelbrock's Performer Plus PN 3712 - 204/214...Your input's greatly appreciated!
Old Sep 11, 2011 | 10:33 AM
78cutlass's Avatar
78cutlass
Engle's 16-18 is also another I was looking at
Old Sep 11, 2011 | 11:26 AM
cutlassefi's Avatar
I can grind you one and deliver it right to you!
That 204/214 is too small and a bit lazy for that compression imo. But depending on your intake and exhaust I probably do something around a 220/228 at .050 on a 110 with .504 lift. Would work well with your combo and you'll hear it to.
Mark
Old Sep 11, 2011 | 01:47 PM
78cutlass's Avatar
78cutlass
Mark,
I'm game! Right now, I have a Performer intake...Yeah, thought about getting something custom with a tighter LSA...The one you recommended sounds dead on...Keep me posted. Thank you.
Old Sep 11, 2011 | 01:49 PM
78cutlass's Avatar
78cutlass
you can email me at:
cutlassfan08@gmail.com
Old Sep 11, 2011 | 02:03 PM
78cutlass's Avatar
78cutlass
Will that grind's lift require me to change springs, since the motor was set up with a W-31 camshaft (the motor was just broken in)?
Old Sep 11, 2011 | 05:24 PM
cutlassefi's Avatar
Probably not but you'll need to verify what spring is in it. Most aftermarket springs are good to .500 lift or so.
Nickyloves442s
Dec 1, 2014 11:18 PM
timholliday
Oct 24, 2014 08:39 PM
lonestarjarhead
Nov 7, 2012 08:40 AM
ijasond
May 13, 2008 08:27 AM
bobolds
Mar 26, 2007 02:45 PM
