Help! Bolt stuck in intake manifold
Tony,
Have a look at this link that Steve posted to help Roger with his aluminum intake. Only difference will be that Roger had a 455. Principle is the same though https://classicoldsmobile.com/forums...tml#post387297
Sorry to hear about the intake problem. Any chance you might want to put a stock intake? You wouldn't run into this problem again, but the 7111 prolly flows better.
Great news! Got the 7111 for 50 bucks, needs a bit of a wire brush and some paint, but it fits great!
I mocked it up, the air cleaner clears the hood by about 3/4''.
Here are some pics of the disassembly.
Here's a picture of the freshly painted intake.
Since you have an aluminum intake, I'd follow Steve's (ah64pilot) advice on this link: https://classicoldsmobile.com/forums...tml#post387299 (permalink 15).
Your question about the turkey tray is answered in permalink 17 of the same thread (reply by oldsmaniac)
Tony,
lol!For EVERYONE, especially if you have an aluminum intake use STAINLESS STEEL BOLTS for the water neck. It is an open hole exposed to water, of course OEM or cheap bolts will corrode and gall in the aluminum. Stainless will help resist the corrosion. Also, finger paint a thin coat of ultra copper on both sides of the gasket surface...All of it. Lay it flat on the manifold, then place your water neck straight down on it, then install your brand new STAINLESS STEEL BOLTS and you won't have this problem again. And if you're using a torque wrench on a water neck something is wrong with you lol! Snug it up and add 1/4 - 1/2 turn, it doesn't have a load on it...don't be he-man haha!
Tony, next time don't be afraid to crank your car up and move it closer to the outlet / welder. An engine runs without a radiator for a few minutes every time you start it...then the thermostat opens and coolant flows.
Don't listen to that Steve guy, he doesn't know what he's talking about
lol!
For the turkey tray, what do you suggest? I've been looking through that link Al posted and I'm still confused
Should i just ditch the tray completely and use RTV? I did that in my marine engine and she hasn't blown out yet. Maybe I've just been lucky... Bloody turkey tray is 50 dollars up here in canada
It always amazes me when lazy/ cheap mechanics won't lube fasteners correctly upon assembly. Sure, it's not probably THEIR problem when it has to come apart next time, but it's SOMEONE'S problem. Look at aggravation and cost incurred because someone skipped 20c worth of anti sieze and the 5 minutes to apply it.
Good thing we're not trying to win WWII with that kind of work ethic.
I wish I could give him a piece of my mind, but it's prolly not worth wasting the energy..
Yeah Tony, Ultra Copper high temp RTV lol! You're crazy! If you hold the gasket in one hand and use a finger to paint it on each side of the gasket then you can set it down on the intake and it'll be a really clean installation.
craaaaapppppppp
Tony jeez Louise I have a 455 intake and you would be welcome to it I can not believe you have ended up so deep I. The sh:-) thole I would still have Yvette performer fixed and sell her to recoup the costs. Sorry to hear bro
I mean, the next one that I don't have yet will still need a manifold lol!
Hey, I sold the L32 engine already. I'm gonna get a 455 / TH400 from a member here...I've already got it planned. I just don't think I can handle living with a garage that doesn't have a 455 on a stand. I've had at least one on the stand for the last 3 years...it just doesn't feel right having an empty stand sitting there lol!
Congrats on the 350 sale. I hope 808Cutlass (i think) will be really happy with it. I can't believe how much this thread got jacked. Good thing Tony is such a nice guy.
You don't need another 455 right now my man. You need to get an air conditioner that works and spend some time with your kids.
If you think having an empty engine stand is bad, wait till the kids start leaving home.
I need a break from the cars...but an engine on a stand with a 10 year build plan...that's a pace I can keep lol!
I heard of Great Wolf Lodge. They had an "Undercover Boss" episode last year to see how the customer service was. Needed huge improvement in the check-in procedures, but in the swimming areas your kids will be 110% safe. They run practice drills with the lifeguards every so often while customers are in the pool. Get ready for a hot humid experience. If I was them I'd be serving ice cold brewskies for the adults.
Have a great trip and enjoy your time away from the man cave.
Tony, the turkey tray was to protect against oil burning on the bottom of the stock intakes (cast iron). As you know they build heat fast and retain the heat. You may be able to get away from that with your 7111 because it's aluminum and dissipates heat faster. I think this is going to come down to personal choice though. I don't see the disadvantage (other than $$$) of the turkey tray going in though. I would love to be there to help you with that; I know they can be a real PITA.
Put some gasket junk over the water ports (I REALLY hope i dont get a leak) Knowing me then i probably will...
We'll see when i fire her up after work today. fingers crossed boys...
Although, i'll be really honest, i put ALOT of RTV around the end seals.... not sure i put enough though. I found the compound kind of runny. Sure hope it seals....
I have a feeling i'm going to be worrying about this all day at work.
ALSO IF ANYONE IS TRYING TO INSTALL A 7111 INTAKE ON YOUR OLDSMOBILE. READ THE MANUAL.
You need to have a couple extra exhaust manifold bolts handy. If you use regular bolts in cylinders 4 and 6, you will be unable to fit a socket.
Take it from me, luckily i had a few extra lying around.
GUESS WHAT EVERYONE!?
THE CUTLASS RUNS!!!!!!!!!!!!!!!
Minor coolant leak through one of the hoses (I didnt tighten it enough) Might get a new clamp, but HOLY GEEZ does the car respond better. She moves really well even under part throttle.
Current Specs:
Idle Speed in PARK: 750 RPM
@ 750 RPM: -21 on my vacuum gauge
temperature: No idea, gauge not hooked up
the idle sounds a "little" more rough. I think i just need to adjust my mixture, but the car fired up within 7-10 seconds of cranking the starter.
Current Specs:
Guys, i painted a light coat of Permatex's Moto1 Ultra Grey gasket maker on the Intake gasoline side, and used Copper gasket maker on the water ports and front/rear rails.
I read the MSDS of most of the permatex products, Moto1 was the only one that resists gasoline, so that's why i chose it.
You might look for a stock A4 intake in a wrecking yard. They are as good as your Performer, and they can usually be bought very cheap. Pull the EGR tubes out and plug the holes with socket head plugs. The threads are standard pipe thread so plugs are easy to come by at your favorite hardware store. Do not buy an A5, small ports for small port heads.
shamusj
Dec 18, 2014 09:28 AM
