Help!!
Old May 1, 2010 | 07:25 PM
'70CutlassHoliday's Avatar
Help!!
Hello all, it's been awhile since I've posted here. So here is my problem, I get a horrible popping through the carb at around 2500 RPM, and complete loss of power (seems like its throwing spark too soon). Tried adjusting timing with no results. I have an MSD 6A ignition box, and MSD Pro Billet distributor, and MSD blaster coil. The Car has become my daily driver, and I need to get it running properly again. I don't want to go blindly replacing parts. So I would greatly appreciate it if someone could point me in the right direction, and yes I have tried to research the issue on MSD's site and found people with very similar issues, but no posts on how to resolve it.
Old May 1, 2010 | 07:39 PM
silverriff's Avatar
1972 Cutlass 455
Do you have the pluggs gapped properly for all that spark your getting. I used to have an old Monte Carlo that would do what your describing after I replaced the sparkplugs for the first time. Turned out I didn't realize the previous owner had put in an HEI that required the plugs to be gapped almost twice the stock gap. I increased the gap, never had the problem ever again.
Old May 1, 2010 | 07:40 PM
Could it be that my mechanical advance is fully advancing too soon?
* posted before I read your post
I don't remember what I set the Gap to. I will check.
Old May 1, 2010 | 07:44 PM
silverriff's Avatar
1972 Cutlass 455
What is the timing you are getting at 2,000 RPM? do you have an adjustable timing light? If not I just picked one up at Harbor Frieght last weekend for about $30 bucks, works great. It could be the timing but it would have to be waaay off to get it to pop like that. It wouldn't be a question of how soon the advance is coming in, bu how much total advance you are getting.
Old May 1, 2010 | 08:04 PM
I just went out and pulled some plugs, I set them to .035.
I don't have a timing light.
She ran okay for about 400 miles.
Old May 1, 2010 | 08:11 PM
silverriff's Avatar
1972 Cutlass 455
Yeah my old M.C. did the same thing, ran ok most of the city driving I did, but it wasen't until I took it onto the highway, weeks after I replaced the pluggs, that it started popping to the point I had to pull over cause I thought the car was going to explode. I guess it was the long sustained crusing at over 2,500 rpm. In any case, what engine is it? And is that the stock gap you have it set to? I know that my 1972 455's stock gap is .040, but the research I have done one upgrading my points distributor says that if I was to put in an HEI, I should gap it quite a bit higher. How do the plugs look? Are they grimy or smell like gas?
Old May 1, 2010 | 08:36 PM
Sounds exactly like what happened to me. When it first started they weren't fouled, when I just pulled a few they seemed to be. The engine is a 350, I went with .035 based on the manual I had for Chevy 350's.
Old May 10, 2010 | 08:22 PM
So I replaced the cap and rotor, new set of plugs, different gap. Same problem but less harsh. She doesn't do it until I drive it down the road, then the misfire starts, and will occur when in park afterward.
Old May 10, 2010 | 08:29 PM
Old May 10, 2010 | 11:42 PM
D Appeldorn's Avatar
trie to disconect the vaciuum advance.
and drive it again, close propperly the vaciuum lines.
older cars did'nt have the advance unit on the distributor.
Old May 10, 2010 | 11:52 PM
When i runing a hei than i need to adjust my plug gap?
That's something new for me, do you know how much?
i have a 350 4bll (used to be a 2)
Runs at higher rpm nicely but can't adjust stationary.
That's a litle ruff and need the choke till it's heat up.
it's stock 350 with i put on a 600 edelbrock 4bll with manual choke and olds 4bll intake.
Thought about it to run bigger rods and primary's.
Old May 11, 2010 | 04:18 AM
I'm running a Mechanical advance
nolabigdawg
Nov 16, 2014 06:45 PM
MJAKS462
Apr 15, 2010 02:34 PM
silverriff
Mar 24, 2010 06:36 PM
martine
Jan 22, 2009 01:13 PM
ToronadoGuyDenver
Brakes/Hydraulic Systems
Mar 18, 2007 02:52 AM
