help-1970 olds cutlass supreme rocket 350
hey everybody, i am currently changing all gaskets in engine, and when i went to look at my pictures for references on where pulleys, brackets and bolts go,
ALL MY PICTURES ARE GONE!!!!
can anyone PLEASE direct me hopefully to pictures of engine and bolt sizes.
also i noticed that where the water pump bolts to timing cover it has pitting. is that bad?
thanks
thanks
you can easily look up the assembly manual at wildaboutcars.com. it will show you where the stuff goes and will tell you bolt part numbers that you can look up the size if you have to. i would also replace hardware that is pitted etc with something new if the old stuff wont clean up on a wire wheel
moys71
February 16th, 2021 08:22 PM
pac937drb
March 23rd, 2013 12:31 PM
