help-1970 olds cutlass supreme rocket 350
Old Sep 9, 2013 | 05:25 AM
rocket350's Avatar
hey everybody, i am currently changing all gaskets in engine, and when i went to look at my pictures for references on where pulleys, brackets and bolts go,
ALL MY PICTURES ARE GONE!!!!
can anyone PLEASE direct me hopefully to pictures of engine and bolt sizes.
also i noticed that where the water pump bolts to timing cover it has pitting. is that bad?
thanks
Old Sep 9, 2013 | 05:45 AM
pogo69's Avatar
morgan
you can easily look up the assembly manual at wildaboutcars.com. it will show you where the stuff goes and will tell you bolt part numbers that you can look up the size if you have to. i would also replace hardware that is pitted etc with something new if the old stuff wont clean up on a wire wheel
Old Sep 9, 2013 | 05:58 AM
rocket350's Avatar
ok thanks, and yea its pitted from rust, cleaned off the rust and it looks like someone took a chisel to it
moys71
Feb 16, 2021 08:22 PM
ros6872
Dec 4, 2016 01:00 PM
pac937drb
Mar 23, 2013 12:31 PM
pac937drb
Mar 10, 2013 04:41 PM
ToBIGWillie
Sep 1, 2010 02:02 PM
