HEI ignition module
Old Aug 9, 2015 | 05:32 PM
s i 442's Avatar
Oldsmobile enthusiast
HEI ignition module
350 Olds engine with a HEI dizzy:
I have an aftermarket HEI distributor, I decided to change out the module to an Accel unit.
When I started the car up I had to up the idle speed by 500 RPMs or the car wouldn't run, it ran rough at start up and at idle.
It started running real good for 2 blocks then dead at 30MPH, coasted to a side street and decide to take a shot and change back to the original module, the car started and I had to idle it back down 500 rpms and its runs great again.
Did I get a junk Accel module or was it not compatible with this dist???
Old Aug 10, 2015 | 07:59 PM
s i 442's Avatar
Old Aug 11, 2015 | 05:11 AM
s i 442's Avatar
OK then, no problem with the site being dead I'll just go over to the Chevrolet site and get some answers.
Old Aug 11, 2015 | 05:13 AM
pherbicide's Avatar
Sometimes it takes more than a few days to get an answer to a question man, patience.
Old Aug 11, 2015 | 06:01 AM
If your HEI works well with the original module, I'd run it. As you said chances are it's bad or not compatible with the pickup sensor.
Old Aug 11, 2015 | 06:13 AM
olds 307 and 403's Avatar
Out of Line, Everytime😉
The Accel stuff is usually good, is it their super high performance module? I have only ran one of their 7 pin modules and two HEI Super coils, one for many years. Why 500 rpm idle, seems pretty low and strange it has to be there. Do the pick up connections look good? Are the weights moving freely with no binding? Does the module pin count match the original?
Old Aug 11, 2015 | 01:06 PM
I do failure analysis for a living and we put the suspect part back in to see if the failure returns. Without doing this you don't really know if the removed part was bad or if something else occurred while you were swapping parts (such as a broken wire losing contact, grounding, etc).
bob p
Mar 25, 2015 07:57 PM
joepenoso
Jun 4, 2014 01:56 PM
aquabird
Mar 31, 2012 10:24 AM
clinton70
Jan 31, 2010 02:53 PM
a6m5zerosen
Nov 29, 2009 12:46 PM
