Heater hose fitting for Edelbrock 7111
Old September 17th, 2016, 12:08 PM
1968 Cutlass Fan!
1968CutlassSupreme's Avatar
Hello all!
I found that the fitting for the heater hose that was on the cast iron intake does not fit the diameter of the hole in the Edelbrock 7111 intake manifold. It is a non-AC heater hose adapter. Has anyone been able to find the adapter that fits in this application?
Thanks!
Bryon
1968CutlassSupreme is offline
Old September 17th, 2016, 01:40 PM
Out of Line, Everytime😉
olds 307 and 403's Avatar
Go to your hardware store and get a 3/4" thread to hose nipple. Pretty sure it is 3/4", not 1".
olds 307 and 403 is offline
m371961's Avatar
I do not know exactly what sizes you are dealing with, but can't you use a brass pipe bushing?
m371961 is offline
Old September 17th, 2016, 01:43 PM
m371961's Avatar
We posted at the same time. Doesn't the original fitting have a small flow restriction hole in it? I am under the impression that the small hole improves heater output, but a regular hose barb will work.
m371961 is offline
Old September 17th, 2016, 01:46 PM
You need a hex bushing:
oldcutlass is offline
Tiberian Fiend
August 12th, 2016 01:49 PM
Redog
April 15th, 2013 08:18 AM
StickW31
September 9th, 2012 06:57 AM
70oldscutlass
April 23rd, 2010 09:00 AM
Kidcutty
March 25th, 2010 09:29 PM
Quick Reply: Heater hose fitting for Edelbrock 7111
