heads
Old Feb 18, 2013 | 11:37 AM
XTREMEGSXR's Avatar
heads
I have seen quite a few comments about number 5 & 7 heads. How are the number 6 heads for a mild build? Also have read that 403 rods are best.
Old Feb 18, 2013 | 11:53 AM
2blu442's Avatar
Yes, the #6 heads are similar in performance with the 5, 7, 7a. Its the #8 that have a significantly larger combustion chamber. Someone else will have to speak up about the 403 rods. John
Old Feb 18, 2013 | 01:52 PM
Octania's Avatar
403 "XC" rods are indeed beastier, slightly.
Old Feb 18, 2013 | 02:32 PM
shakeyhands73442's Avatar
I am going from 8 to 6. I've been told it will be a pretty noticable difference.
Old Feb 18, 2013 | 03:36 PM
olds 307 and 403's Avatar
Out of Line, Everytime😉
You will have 10+cc smaller chamber plus better exhaust side flow. Make sure to use the .028" Corteco composite head gaskets from Rocket Racing or the .011" shim head gaskets from MJ Proformance unless at 0 deck. All Olds rods are so so strength wise plus heavy. I am sure the Scat sbc rods I am using, will much stronger and lighter.
Old Feb 18, 2013 | 05:00 PM
XTREMEGSXR's Avatar
What cars had the 403xc rods? Does anyone have a set they want to sell?
Old Feb 18, 2013 | 07:22 PM
I may have a set soon. They will need the big end resized, pretty sure a rod bearing is spun.
Old Feb 18, 2013 | 08:09 PM
Just for the sake of thoroughness, as I have seen vague references to "Smitty at MJ Performance" before, with no clear contact info, please allow me to state:
MJ Proformance
Mark "Smitty" Smith
4444 Meese Road, NE
Louisville, OH, 44641-9119
(330) 875-8096
(330) 495-4582
MJProformance.com ("Under Construction" placeholder page)
smitho455 at att dot net
By the way, what does he get for those shim gaskets?
Old Mar 7, 2013 | 06:22 PM
Sampson's Avatar
Shim gaskets
Are the shim gaskets used in conjunction with head gaskets to adjust compression?
Old Mar 8, 2013 | 04:44 AM
No (and yes).
The original head gaskets used by the factory were just 0.016" thick steel stampings. That's what we're talking about here.
They can be hard to get nowadays, and the most common FelPro gaskets are 0.030" thicker, so will drop compression about a point (if I recall my calculations from a while ago).
On the other hand, back in the '70s, people sometimes used shim gaskets (not the same as the OEM gaskets we're talking about) to reduce the compression of high-compression engines, in order to be able to use the gas that was available at the time. It is possible to run across cars with these gaskets on occasion.
Old Mar 8, 2013 | 08:30 AM
Sampson's Avatar
Originally Posted by MDchanic
No (and yes).
Thanks for the info Eric. I may be using bad etiquette here and do not mean to be stepping on this thread. I am installing Speed Pro flat tops in my 350 that are 30 over in conjunction w/#6 heads. Compression will be a little above 10:1 which has me worried about pump gas. Are the shims still available to bring CR down a touch. I would like to be between 9.5:1 & 10:1
Old Mar 8, 2013 | 08:36 AM
I have no idea, but if they are available, they are not a "best practice" sort of a modification.
Did you cc the heads to calculate that CR, or did you use the nominal 64cc volume? The nominal volume is seldom accurate, and the actual volume tends to be higher.
Also, did you calculate the CR with the thicker FelPro gaskets or other gaskets?
Old Mar 8, 2013 | 11:10 AM
J-(Chicago)'s Avatar
Seasoned beater pilot.
You can order cometics gaskets in any thickness you like, they just aren't cheap.
Old Mar 8, 2013 | 03:07 PM
Sampson's Avatar
Gaskets
Thanks for the info. I also talked w/Smitty from MJ Performance today who told me that he could also make gaskets to order.
Old Mar 8, 2013 | 03:12 PM
Sampson's Avatar
I was using .039 from Fel Pro. Talked w/ the builder today and he said the heads. C/C 'd. 66cc before cleaning and valve job so it only gets better from there. Also talked w/Smitty from MJ Performance today who said he will build up to 10:5 cr with iron heads without issue. I will sleep better tonight. Thanks for the help
Old Mar 8, 2013 | 03:19 PM
You're welcome.
64 CUTLASS KEN
Dec 7, 2020 06:43 AM
olds4life
Dec 25, 2012 12:56 AM
Oldsmaniac
Nov 1, 2010 06:37 PM
gearheads78
Nov 10, 2009 09:31 PM
DarkStar
Oct 21, 2009 07:35 AM
