Header question
When i installed my long tube headers on my 350, i had to remove the dipstip to mount the headers. Afterwards, i bent it slightly and carefully tapped it back in. The tube of the dipstick is now on the outer side of the plate of the headers.
because of the bent i make, the dipstick doesnt slides in as it did before, but its not really a problem if it goes the whole way down.
Hope this helps
Hope this helps
I have noticed the same thing on my 400ci big block in my 67' 442 with long tube headers. The headers were already on the car when I bought it. Between the header, the steering shaft, and hard brake lines coming off the master cylinder, it's a very tight fit, and I suspect the dipstick tube was bent to get it into the only position where you can get the dipstick out at all. It is a real pain in the arce to get it in and out. I wish a manufacturer made a thinner, more flexible dipstick that would not bind as tightly inside the tube. I think that would solve the issue. Maybe someone else on here knows of a manufacturer who makes one like that and will chime in???
I ran into the problem on installing the tube back on my 88 and just doing the top end on my Dodge Magnum 360. The Olds, must have a bend, I used a different stick, now go up to the SF mark for full. The Dodge is completely ignorant. The other V6 Magnum and Olds dipsticks are too short. I even ground on the dipstick, barely made a difference. I took a pry bar and pushed where it looked bent, now goes in with a couple of tries, no 25 tries. Carefully bend and test, remember, they can be fragile and break off, good luck.
