Which head gaskets do I use?
Old Nov 24, 2013 | 07:20 PM
HitTheHole's Avatar
I have a 1970 Olds 350 with #6 heads. I'm having it bored 0.030" over. I understand the stock bore size is 4.057" and I read that the gasket-bore size should be 0.050" larger than the engine bore. If I do the math, that means a bore size of 4.137"? I'm using Speed Pro/TRW Forged 6cc Dish Top Pistons #2321F30. I also read that Cometic MLS head gaskets were highly recommended with a thickness of 0.027"? I'm just having trouble figuring out which head gaskets to order. Will these work? http://www.summitracing.com/parts/cg...ake/oldsmobile
Old Nov 25, 2013 | 09:23 AM
Lars's Avatar
Felpro 8141 should work, are you going to zero deck the block?
Old Nov 25, 2013 | 09:29 AM
The bottom line is that head gasket selection is a function of your intended use of the motor and your selection of all the parts. The FelPro gasket works great but has an 0.040" compressed height. The result is a slightly lower CR. The Cometics are a fantastic product but more expensive. Your call if you need the slight increase in CR or not.
Old Nov 25, 2013 | 04:31 PM
Lars's Avatar
Sorry thats 8171. We need t know how far is your piston is in the hole. Shoot for 40 thou piston to head clearance.
JpMotorsports
May 15, 2014 07:08 AM
blackbird51
Jul 10, 2013 11:29 AM
Stevec
Mar 15, 2012 01:19 PM
Al2011
Feb 15, 2012 03:57 PM
327supreme
Feb 15, 2009 05:45 PM
