Head Gasket choice
Old Dec 11, 2012 | 03:50 PM
Redog's Avatar
Head Gasket choice
Going to remove and have the heads done (new valves, springs, hardened seats and maybe a 3 angle valve job while I'm at it) and I want to know which HG I should use?
Don't want to use RTV!!
1967 Olds 330 with Hi Comp heads
Old Dec 11, 2012 | 05:10 PM
442Harv's Avatar
You can not use RTV, for head gaskets. You neeg head gaskets. The problem is you have very little choices, probably Fel Pro, is what is a valable, or maybe Cosmic?
Old Dec 11, 2012 | 05:14 PM
olds 307 and 403's Avatar
Out of Line, Everytime😉
Add Mr Gasket, Corteco and ROL to that list.
Old Dec 11, 2012 | 06:02 PM
m371961's Avatar
I always liked Fel-Pro permatorque on stock engines.
Old Dec 11, 2012 | 06:45 PM
captjim's Avatar
I am going to assume that he was joking......
Old Dec 11, 2012 | 07:55 PM
Redog's Avatar
I did not mean I wanted to use RTV in place of a head gasket, I just don't like using RTV at all. I only use it when I have to.
AM I correct that if the heads have to be milled, I have to mill the intake as well?
Old Dec 12, 2012 | 04:19 AM
captjim's Avatar
Not unless you hack off a whole bunch. A clean-up cut or two, no problem.
Old Dec 12, 2012 | 07:40 AM
Run to Rund's Avatar
Notwithstanding your aversion to RTV, it is the best way to seal the water port areas (not the fuel/air port areas) of the intake gasket, and the ends of the intake to the block. Today probably most people use RTV only for end seals. The original rubber seals were a pain especially after the heads were surfaced--they tended to slip out of place and leak.
The major sources for head gaskets were listed above; the Olds race shops often carry gaskets, such as Rocket Racing, etc. as is easily found with a search or on ROP.
Old Dec 12, 2012 | 09:33 AM
rcrac3r's Avatar
Felpro would be a good choice. Never had any problems with any of their gaskets.
Bobac455
Dec 4, 2013 09:23 AM
aussiemobile
Feb 15, 2013 07:31 AM
harry k
Nov 21, 2012 08:54 AM
dallasite21
Jun 20, 2010 05:37 AM
Sixoh
Aug 8, 2006 05:11 AM
