Gasket for oil pressure sending switch
Old Jun 3, 2016 | 01:08 PM
dnohe's Avatar
In the picture below, I'm leaking around the oil pressure sending switch (34-092) and about to order a new one. I havent taken the old one out yet to look at it. Is there a gasket that will come with the new component or do I need to add something to it to form a seal.
dean
Which is exactly what the factory did on cars with gauges. The factory part looks like this and is available repro, but hardware store 1/8" NPT fittings work just fine if you don't care about 100% correct appearance.
Old Jun 3, 2016 | 01:15 PM
dean
The sender is pipe thread. Use dope on the threads. Teflon tape may insulate the ground path for the sender.
Old Jun 3, 2016 | 01:20 PM
NPT=national pipe thread. It is tapered and self sealing, you can use a small amount of thread sealer if you want to. Do not use Teflon tape as they may interfere with the connection and cause erratic readings.
TheRuss
Sep 30, 2025 05:33 AM
boondocker
Aug 22, 2011 10:03 AM
mmurphy77
Mar 13, 2011 08:08 PM
boese1978
Jan 22, 2008 11:56 AM
texasred
Jul 31, 2007 10:18 AM
