fuel sender 71 supreme
Old Jul 3, 2020 | 03:14 PM
JOHNNYOLDS442's Avatar
Olds Specialist LOL
Fuel sender
I think i have the two line with the retun line because there is that extra line that runs up front to the canister thats not there?
my question does anyone know if i can get the single line if i had the two line and just dont hook it up?
does it need the return line o breath? im tring to fix the gas gauge and i tested the gauge works when grounded.
tanks johnny!
Old Jul 3, 2020 | 07:01 PM
So what is the issue with the fuel gauge?
Old Jul 3, 2020 | 09:35 PM
Olds Specialist LOL
I tested the gauge wire by grounding it and it goes down to empty right now it reads Way past full almost to the hot temp idiot light so it’s most likely the sending unit I’m gonna pull the tank I already checked the ground on the tank underneath that is fine
Old Jul 4, 2020 | 07:33 AM
RetroRanger's Avatar
72 Olds CS
Mine is like that i fill it it goes way past full, but it drops down uniformly untill is gets to below 1/4 then it seems to pick up speed. I can attest when it says E it means it
i assumed its the wrong resistance sender, but it works enough so i dont bother w it.
or does yours not move at all?
Old Jul 4, 2020 | 07:54 AM
Two line sending units are for cars with fuel return. Single line senders are for non-fuel return applications. The charcoal canister does not connect to the sender, it connects to vent lines in a different location on the tank. This is shown in Chapter 8 of the Chassis Service manual.
Old Jul 4, 2020 | 01:31 PM
I had the same issue on my 70 Supreme and also on the 71 convertible with the needle pointing way past FULL towards the HOT light. On the 70 I dropped the tank and found it was caused by a loose connection on the wire at the sending unit. I crimped the connector and never had the issue again in 20 years or so. On the 71 I am too lazy to drop the tank so I just wiggle the sending unit wire behind the license plate and the gauge starts working right again, until I hit a big bump or something.
71cutlass350
Mar 27, 2018 09:21 PM
Oldssupreme
Jan 19, 2016 05:17 PM
olds408
May 4, 2014 02:19 AM
My72Cutlass
Jun 13, 2013 07:10 AM
Kidcutty
Mar 28, 2011 07:56 PM
