fuel pump rebuild, help!
Old Apr 15, 2013 | 09:14 AM
thapachuco's Avatar
Hi,
I have a fuiel pump from a 1960 371 dynamic, that i am rebuilding. It is all apart and soaking in cleaner.
I cannot figure out how to separate both the lower and upper diaphragm plates. how do i do this?! '
The pump i have looks like this
The diaphragms look like this: is this how it is supposed to be separated
it seems like they are pressed together. there is no bolt to separate them both.
help please!
Also, i noticed there was a fair amount of oil inside the pump, is this normal?
Old Apr 15, 2013 | 07:30 PM
thapachuco's Avatar
no one?
Old Apr 15, 2013 | 07:50 PM
MellowYellow's Avatar
If all else fails:
http://arthurgouldrebuilders.com/about/
http://cowboyjohnsautoparts.com/anti...uild-kits.html
http://www.classicpreservation.com/index.html
http://www.maritimedragracing.com/th...automotive.htm
If you buy a kit from one of these vendors, very likely they'd pass along a couple tips & tricks.
Old Apr 15, 2013 | 07:56 PM
This might answer your question:
http://www.stovebolt.com/ubbthreads/...81775&page=all
Not exactly the same, but good pics:
http://www.amosauto.com/Articles/Cla...ac-fuel-pump-1
Old Apr 16, 2013 | 09:40 AM
thapachuco's Avatar
thanks for the reply. I bought my kit thought classic restorations. just wanted to see if anyone has done this already.
Old Apr 23, 2013 | 09:36 AM
thapachuco's Avatar
is there a reason why there would be oil in my fuel pump? I notice it more where the actuating arm is inserted as well as in the diaphragm areas upper and lower.
Old Apr 23, 2013 | 12:36 PM
The housing is open around the lever arm, so oil from the block will get into that area. If there is oil on the other side of the diaphragm then it is likely ruptured.
Old Apr 23, 2013 | 12:44 PM
thapachuco's Avatar
Good to know, thanks!
jims2000lt
Jul 7, 2012 11:20 AM
lluebke
Apr 28, 2012 05:10 AM
67 Cutlass Freak
Feb 1, 2012 02:58 PM
Captain_Fish
Mar 2, 2011 04:30 PM
442oldslawyer
Apr 29, 2010 09:22 PM
