Fuel filter bolt 1 inch in diameter 330 Olds Cutlass carburetor
Old Jun 2, 2020 | 02:49 PM
Jonmueller1's Avatar
I am looking for the gasket that goes on the 1 inch bolt that holds the bronze fuel filter into the carburetor (4 barrel). Can't find it at a parts house. Do I have to buy a whole carb rebuild kit with set of gaskets to get this? Unable to locate one separately. Wanted to replace it after changing the fuel filter just to be safe. To make sure no possibility of a leak. What do you suggest? Thank you for response. Jon M.
Old Jun 2, 2020 | 02:55 PM
OLDSter Ralph's Avatar
Which 4 barrel carburetor ? Try Mikescarbs in Washington state.
Old Jun 2, 2020 | 03:22 PM
Thank you Ralph: I called them and sent pictures and specs about the carb and they said they would reply back. Your quick response is very much appreciated, Jon M.
Old Jun 2, 2020 | 03:47 PM
Get several of the washers, then you will never have one go bad,<--HUMOR I have used them and they are quite helpful.
Old Jun 2, 2020 | 04:21 PM
Be aware there are two kinds, one that goes around the threaded fitting and butts up against the hex portion, one that goes on the end of the opening that fits into the hole in the carb. i don't remember if the two styles are the same diameter or if they are different, though.
Here are some vendors that show the gaskets:
https://www.carburetion.com/sitesear...uel%20Fittings
https://quadrajetparts.com/inlet-fit...ack-p-124.html
https://www.summitracing.com/search/...ze-1%3A1-20-in
Old Jun 2, 2020 | 04:42 PM
Many Thanks for excellent info!
jpc647
Nov 2, 2014 03:40 PM
mmurphy77
Aug 16, 2013 06:47 PM
Cutdawg78
Apr 23, 2012 06:13 PM
lmarquette
Mar 17, 2012 08:18 PM
BStone
Aug 13, 2011 06:16 AM
