Fan Shroud
Fan Shroud
How importnat is the fan shroud? Mine has been missing ever since I have owned the car. I dont think i have heatin issues (the idiot light does not come on). Is this something i should seek out and replace? I drive a 69 Delta. Is the shroud unique to the car or the motor?
You can add a fan shroud if you want, but it's probably not needed if you don't have any problems with cooling.
Does the car have air? Some cars only used fan shrouds with AC but I'm not familiar with that model, can't hurt anything to do it. I would also loose the idiot light and install a water temp gauge at the least in any case.
The first thing I do on any car I get is install gauges, idiot lights are called that for a reason but you can also be an idiot if you don't keep checking the gauges. I like to keep the idiot lights working along with the gauges.![Roll Eyes (Sarcastic)](https://classicoldsmobile.com/forums/images/smilies/rolleyes.gif)
![Big Grin](https://classicoldsmobile.com/forums/images/smilies/biggrin.gif)
Giddy
March 10th, 2009 11:37 AM
