Fan Shroud
Old Apr 19, 2009 | 03:06 PM
bcg88's Avatar
Fan Shroud
How importnat is the fan shroud? Mine has been missing ever since I have owned the car. I dont think i have heatin issues (the idiot light does not come on). Is this something i should seek out and replace? I drive a 69 Delta. Is the shroud unique to the car or the motor?
Old Apr 19, 2009 | 06:45 PM
Not every car made had a fan shroud. How would you know if it's missing if it never had one when you bought the car?
You can add a fan shroud if you want, but it's probably not needed if you don't have any problems with cooling.
Old Apr 20, 2009 | 04:22 PM
Warhead's Avatar
I'm pretty sure your car came with one.
Down here, you pretty much need one, give your cooling system a break.
You did not say where you live.
Ditch the idiot light.
JMO
Jim
Old Apr 20, 2009 | 07:18 PM
Lady72nRob71's Avatar
I would recommend one. The idiot light does not come on until 240* or so... If it did come with one, it was for a good reason anyway.
Old Apr 21, 2009 | 08:21 AM
bcg88's Avatar
I will see if I can locate one. Thanks for the advice.
Old Apr 21, 2009 | 08:51 AM
Bluevista's Avatar
Registered
Does the car have air? Some cars only used fan shrouds with AC but I'm not familiar with that model, can't hurt anything to do it. I would also loose the idiot light and install a water temp gauge at the least in any case.
The first thing I do on any car I get is install gauges, idiot lights are called that for a reason but you can also be an idiot if you don't keep checking the gauges. I like to keep the idiot lights working along with the gauges.
shamusj
Jan 13, 2015 05:44 AM
rmoths
Dec 21, 2013 11:03 AM
KZ442
Nov 9, 2010 05:01 AM
hammerit
Feb 24, 2007 08:06 AM
