Exhaust bumps
Old Nov 1, 2008 | 03:13 PM
mp71conv's Avatar
Exhaust bumps
What exactly are the bumps on olds heads.
I have no7 heads and have felt inside them
and found what i think are the bumps but they seem
to be a long gradual bump
Grinding those down should not go through
anything important will they?
Old Nov 1, 2008 | 06:50 PM
In some applications, Olds motors uses Air Injection Reactor (A.I.R), also know as air injectors or a "smog pump". The castings have these bumps to allow the holes to be machined for the A.I.R. tubes. The bumps are solid and can be ground down with no problems.
Old Nov 2, 2008 | 12:53 AM
88 coupe's Avatar
Junior Member
........ The bumps are solid and can be ground down with no problems.
Whether is makes any difference, depends which "head porter" you ask.
Norm
Old Nov 2, 2008 | 06:48 AM
Norm
Fair enough. Most seem to agree that raising the roof of the exhaust port in conjunction with also raising the floor is a net benefit for Olds exhaust ports. Short of welding, the only easy method of raising the floor is to use the inserts that Dick Miller and others sell. I have not personally tried these and would welcome any comments from folks with firsthand experience.
Old Nov 2, 2008 | 11:09 AM
captjim's Avatar
"Most seem to agree that raising the roof of the exhaust port in conjunction with also raising the floor is a net benefit for Olds exhaust ports."
That seems to be the consensus on most engines.
I have those DM inserts. We have a new Land-N-Sea dyno at the shop. I may pull my 10.4 to 1 355 out of the wagon and fool around with a few things. I'll try the inserts, maybe even see what difference there is with shorty headers, long tubes, and manifolds, etc. If anyone has something they want to donate for the experiment, I'll be glad to try it out.
Old Nov 2, 2008 | 02:30 PM
Yeah, mine was kind of a "DUH" statement. Raising the exhaust ports makes the port straighter and thus better flowing. Olds engines are especially sensitive to this since the ports make about a 90 degree turn from the valves. Many engines, like Chebbies, already have straighter, higher exhaust ports.
Old Nov 2, 2008 | 08:05 PM
88 coupe's Avatar
Junior Member
........ Short of welding, the only easy method of raising the floor is to use the inserts ........
How are they held in place?
Mine (both intake and exhaust) are filled/welded.
Norm
Old Nov 3, 2008 | 07:52 AM
Norm
The DMR inserts are actually flanges that sandwich between the headers and the exhaust face of the head. The flanges have tabs along the lower edge of the port cutouts that bend down into the ports to fill this space. The tabs must be custom fit to the ports. Not an ideal solution but a lot cheaper than welding/filling. The gas under the tabs stagnates and so the flow follows the raised path.
Old Nov 3, 2008 | 04:12 PM
captjim's Avatar
http://www.dickmillerracing.com/cgi-...db4+1233129627
Old Nov 3, 2008 | 04:17 PM
Oldsguy's Avatar
Past Administrator
Not a bad price either.
Old Nov 4, 2008 | 08:22 AM
88 coupe's Avatar
Junior Member
........ Not an ideal solution ........
I think that qualifies as an understatement.
Norm
Old Nov 4, 2008 | 11:04 AM
captjim's Avatar
The guy who owne's the shop I work at says they have been using a similar insert on SBFs for a long time, only difference is that they are individual instead of one piece. He has dyno, flow bench and track data that indicated they do work. Are they better than filling the floor, probably not. Are they better than nothing? I can't say.
Johnd
Body work
Dec 23, 2013 07:16 AM
88hurstolds
Oct 15, 2012 07:25 PM
auto_editor
Apr 9, 2012 07:20 PM
import extermination
Nov 21, 2011 10:31 PM
65OldsDelta88SuperRocket
Oct 27, 2011 09:16 PM
