Engine vacuum hose help!!!
The vacuum hoses on this car were not all hooked up right when I got it and to make matters worse I took everything off and left it off for a year. So I'm struggling to get it all together. After examining the diagram in my manual I have discovered that I need a CTVS, DTVS and VRV. Does anyone know what those do or where I could get them? I actually have one of those items but don't know if it is the ctvs or dtvs. It appears to be some sort of temperature controlled valve. In the diagram the VRV appears to be some sort of diaphragm? Any tips are much appreciated. Oh, and if anyone knows what TACS stands for that would be helpful
Okay I found out that CTVS and VRV stand for:
Choke Thermal Vacuum Switch
Vacuum Regulatory Valve
I'd still like to know what these do and where I can get them though?
aha, that would be helpful wouldn't it My bad. Its a '77 cutlass 442 with a 350 V8. All I know about the carburetor is that its a 4bbl. Attached is a diagram of the vacuum hose stuff with all three items pictured.
From another thread I am picking up that the CTVS may only have two ports instead of three as pictured in the diagram. Would this make sense? I have a two port valve on the right side of my engine but did not think it was the CTVS because it only had two ports. Any thoughts?
I've attached a picture of the engine with several things circled. I believe the CTVs may be the orange thing in the front and the TACS is one of the two ports in the back?
Great! That is helpful. Why didn't the diagram I have show all that? Its from a '77 all series manual.
So the orange two port thing on my engine is the egr/dtvs.
I checked at the local Federated Auto Parts store and they did not know what the dtvs, ctvs, or vrv were or where to get them. So I'm still stumped.
Are you sure it's the original carburetor?
Eric,
In the picture the orange thing is the egr/dtvs (I think) but there should be another dtvs (still don't know what that stands for. Of the two ports in the back one goes to the vacuum booster for the brakes and I believe the other must be the one labeled as TACS in the diagram. And no I'm really not sure if the carb is original. How do I figure that out? I want to actually understand what everything does before I put it back on.
DTVS stands for Distributor Thermal Vacuum Switch.
Unfortunately, I know next to nothing about these emission controlled engines, so I can't explain anything specific about it.
I would recommend the factory service manual, which generally has an excellent explanation of the function of each of these components.
Would a 78 pontiac sunbird all Gm 151 engines distributor thermal vacuum switch fit on my 77 cutlass? Its advertised on ebay as part #546896.
I checked the carb and it is a Rochester Quadrajet and has the following numbers on the side:
17056250
1056 AHA
So to recap, I am trying to understand how the vacuum hoses should be hooked up:
1. I have the egr-tcv, egr/dtvs, ctvs, and pcv stuff.
2. I do not have the dtvs(the hole in the block for it has a plug instead) and tacs(?) and I appear to not have all the same ports on my carb as pictured in either diagram posted above.
Thanks again for the help.
P.S. I have at least two fewer carb ports than those pictured in MDchanic's diagram.
17056250
1056 AHA
I can't find a '76 diagram, but I'm sure one is out there. It is probably different than '77 - they changed them constantly.
Remember, one solution is to dispense with all of the emission control crap, use a carb. and distributor set up for an earlier car with similar displacement, compression, and cam characteristics, and don't worry about it.
I guess I dispensing with the emissions stuff would be a possibility, but I'm leaning towards trying to get everything hooked up as close to original as possible. Wouldn't removing the vacuum hoses reduce performance quality or is it the other way around?
Yes, just removing he hoses would probably make it run worse (remember, I'm not an authority on these years), but replacing the carb and the timing components with ones that are calibrated for an earlier engine should work fine.
On my 76 with a 455. I capped the EGR and just run full manifold vac to trans mod and ported to the dist. I dont have any of those switches. The ports on the intake have plugs in them. You could hook it up like this to run the car till you get it all figured out. Thats if your trying to keep it original.
Hi
I also have a problem with a vacuum hose. It's the hose from the thermatic sensor mounted on the air cleaner to the vacuum break... Can't find the vacuum break.
Can someone send me a pic with the right connected hose?
On the picture there should be a hose on the second port of the thermatic sensor.
please help.. 98regency
