Engine issue out of the blue ?
1972 cutlass 350 4bl
car ran like a top when last driven and parked in late feb . ( garage kept ) went to drive on Friday and it sounded like this and would not stay on
any thoughts on issue
first video is initial issue
second video is after changing all plugs and fuel filter
There are no videos. You can't post most videos here on this site because it is not designed for posting videos.
I suggest you post a video to Youtube then provide a link to Youtube.
You might try to explain the best you can what you personally believe the engine is or is not doing e.g. missing, running rough, fuel starvation, electrical etc.
When was the last time it had a complete tune-up. It may just be it needs new contact points, rotor, distributor cap - simple stuff. When they sit a spell depending on location, they can accumulate moisture and if the contact points were nearly so ready for a change, this could have accelerated the contact points going bad. Possibility of a minor vacuum leak.
Thank you
car won’t idle , have to press gas yo keep running and it’s super rough and shaky while doing so . Sounds like a diesel or crop duster at the exhaust end when doing so... sputtering
car then immediately dies when put in gear .
I will post you tube video and link later I appreciate that tip
