Engine issue out of the blue ?
Old Apr 12, 2020 | 11:20 PM
Dranom's Avatar
1972 cutlass 350 4bl
car ran like a top when last driven and parked in late feb . ( garage kept ) went to drive on Friday and it sounded like this and would not stay on
any thoughts on issue
first video is initial issue
second video is after changing all plugs and fuel filter
Old Apr 13, 2020 | 12:05 AM
There are no videos. You can't post most videos here on this site because it is not designed for posting videos.
I suggest you post a video to Youtube then provide a link to Youtube.
You might try to explain the best you can what you personally believe the engine is or is not doing e.g. missing, running rough, fuel starvation, electrical etc.
When was the last time it had a complete tune-up. It may just be it needs new contact points, rotor, distributor cap - simple stuff. When they sit a spell depending on location, they can accumulate moisture and if the contact points were nearly so ready for a change, this could have accelerated the contact points going bad. Possibility of a minor vacuum leak.
Old Apr 13, 2020 | 08:47 AM
Dranom's Avatar
Thank you
car won’t idle , have to press gas yo keep running and it’s super rough and shaky while doing so . Sounds like a diesel or crop duster at the exhaust end when doing so... sputtering
car then immediately dies when put in gear .
I will post you tube video and link later I appreciate that tip
Old Apr 13, 2020 | 08:51 AM
When was the last time (at what mileage) did it have a complete & thorough 'tune-up'? What is the current mileage or how many miles since the last complete tune-up?
Old Apr 13, 2020 | 09:02 AM
JohnnyBs68S's Avatar
Lacking the videos...........did it run any differently (better or worse) after the spark plugs and fuel filter were changed? If it ran worse after the plug change, double check your spark plug wiring to be sure you didn't mix up a couple (I'll assume you gapped all the new plugs properly before replacement and none were left loose). Check to see if the coil wire is properly seated at both ends. If it ran a little better, continue with the tune-up w/ new cap/rotor/points and maybe a new set of plug wires. Also check for vacuum leaks, a hose may have split while sitting and is now causing it to run real lean
Old Apr 13, 2020 | 09:14 AM
cherokeepeople's Avatar
i would start by checking vacuum hoses.
Old Apr 13, 2020 | 09:28 AM
redoldsman's Avatar
Proud Viet Nam Veteran
It is possible you had a rodent chew a wire or vacuum hose during the winter.
Old Apr 14, 2020 | 08:44 AM
Jhucks03's Avatar
Float stuck?
Old Apr 14, 2020 | 07:30 PM
if you run the rpm's up say 1500 or so does it smooth out?
Dranom
Apr 14, 2020 06:34 PM
BlueCalais79
Dec 9, 2016 06:32 PM
EightballZ
Apr 3, 2016 11:08 AM
910hemingway
Oct 14, 2014 06:06 AM
