Engine decoding help
Old Aug 17, 2024 | 12:08 PM
Sarge8906's Avatar
Hi,
I just recently bought a 1979 cutlass supreme brougham. I obviously know someone has swapped it from diesel to gas. But I am trying figure out what block it has. Have searched everywhere and can not find anything about block identifier. Here are the casting #'s.
7582GM57LD any help would be greatly appreciated
Old Aug 17, 2024 | 12:25 PM
Sugar Bear's Avatar
Id it definitely an Olds engine? Oil fill tube is a vertical pipe on RF of engine, distributor in the back?
Old Aug 17, 2024 | 12:28 PM
Sarge8906's Avatar
Id it definitely an Olds engine? Oil filter tube is a vertical pipe on RF of engine, distributor in the back?
Yes you are correct.
Old Aug 17, 2024 | 12:43 PM
Originally Posted by Sarge8906
Hi,
That is an Olds diesel block. If it is currently running as a gas engine, someone converted it. Back when the diesels were new, Joe Mondello sold a conversion kit that included a gas engine cam and some other parts. You supplied the heads, intake, carb, and distributor.
Reese Neis
Apr 16, 2021 03:42 PM
Jerm1072
Feb 4, 2016 10:03 AM
junkyard junky
Nov 29, 2015 07:12 AM
nitrojunkie1029
Nov 11, 2013 10:07 AM
350\cutlass
Dec 9, 2010 09:57 AM
