HELP! Engine Plans for my 81' Supreme
Hey guys! So heres the scoop. I have been saving up money and I am finally ready to take the sb chevy out of my 81' and replace it with an Olds. The question I have is this. Big block or small block. I want to build my Cutlass into a nice street machine with some fairly good numbers. I don't want to be screeching my tires everytime I'm at a stoplight..unless i want them to .
So here is what I'm asking.
Has anyone swapped a big block in a gbody? How complicated is it?
Should I just go with a built small block?
Are more parts available for any certain block?
Cost effectiveness?
I will also be doing most of the work myself or with one other buddy so ease of installation will play a part but we are both fairly knowledgable in mechanics and slight modification. I would like to lean away from custom fabricated parts though.
Any help would be much appreciated and I will start a new thread with continued photo updates once the work begins.
Thank you!
Cost effectiveness?
Thank you!
budget is not a concern at the moment. I am starting off with finding the block and going from there. Not to say I have an unlimited amount of spending cash but I am sure i can handle what it takes to get something betweeen 3-400 hp. (most likely 350).
located in minnesnowta which makes my job even harder as there isn't many resources available
i would prefer to stay under 5000 for the time being knowing full well i may not get the hp im looking for right now but i can always keep my car in storage until more funds come in
yeah i think chicago is a little far of a drive and a little to expensive to ship. I will keep you in mind in case nothing turns up closer though.
and i would be satisfied with low 13's high 12's for the moment. i am more interested in cost effectiveness for my gbody. i dont know how expensive/frustrating it would be to throw a big block in and need to know if a built small block would be a better road to take.
i have seen plenty of people complain about the numbers there big blocks have after throwing tons of money into them
mid-low 12's should be a cake walk as long as you have traction.
355 ~10.0 compression shortblock
mild ported 5,6,7,7a heads
rpm intake
headers and good 2.5" exhaust
th350 3.73 or 4.10
cam and converter to match the RPM range to want to run
I would set up something with a 5500-5800 shift point
rpm intake
th350 3.73 or 4.10
Starting with entirely fresh machine work and parts, either would probably be around 4-6k
There is always lots of engine cores on CList.
The link is for the St Paul area
http://minneapolis.craigslist.org/se...minAsk=&maxAsk=
jeffreyalman
October 6th, 2019 10:15 AM
