Egge 1967 330 piston reviews?
Old Jun 12, 2010 | 10:35 PM
wjustinmartin's Avatar
Not only was the rear driver's side lynch pin broken, but the piston was also cracked
Does anyone have any experience with Egge reproduction pistons for a 10.5:1 1967 330?
Old Jun 13, 2010 | 05:30 PM
And if not the Egge pistons, what pistons to keep the higher compression ratio?
Old Jun 26, 2010 | 04:46 AM
88 coupe's Avatar
Junior Member
No experience with that particular application, but I have done a couple of other Olds engines. Egge pistons are manufactured "in house" and I've found them to match the original specs exactly.
Norm
Old Jun 26, 2010 | 04:49 AM
You may also want to consider JE Pistons and Arias Pistons.
Old Jun 26, 2010 | 12:58 PM
Well, by the time I started researching the shop rebuilding the engine had already purchased some - I don't know exactly which kind or from who.
I am probably being too persnickety and controlling (which comes from a lack of confidence), but whatever the shop used is hopefully right. DAMN I wish I could perform that kind of work; maybe one day.
Old Jun 26, 2010 | 05:33 PM
Well, ask to have a look at the part number/specs. on the reciept that they got when they purchased the pistons. There should be something there to tell you what you have.
ankerclanker
Oct 21, 2014 07:29 PM
AirborneRME
Jun 5, 2013 06:24 AM
w-30dreamin
Mar 23, 2013 06:54 PM
billykissell
Apr 6, 2011 02:45 PM
Jon Dahl
Feb 28, 2009 08:58 AM
