DVCS and transmission.
Old Dec 28, 2012 | 04:38 AM
Seff's Avatar
The diagram in the CSM states that there should be a t-connector in the routing that connects the DVCS to manifold to transmission vacuum. Will it work just as well to connect the transmission to its own manifold vacuum port, or could that be why I'm getting poor mileage? As I understand it, part of what that switch does it make the more advance when you're traveling at high speed, which it can't tell unless it's connected to the transmission, right?
Old Dec 28, 2012 | 07:16 AM
Both need to be connected to manifold vacuum. It doesn't matter if you tee them together or connect them separately, the manifold itself is a big "tee".
Old Dec 28, 2012 | 10:18 AM
Seff's Avatar
Gotcha.
Damn it, then my mileage suckage is caused by something else. >.>
Macadoo
May 18, 2014 04:43 PM
Cesar Malta
Jan 14, 2008 06:42 AM
mikey0560
Oct 14, 2007 09:08 AM
1980oldscuttnewbie
Apr 30, 2007 05:22 AM
sbs4332
Sep 30, 2006 09:39 AM
