Which distributor?
Which distributor?
Hello all, I'm looking to buy a Pertronix setup for my car and wondered if you can help me out. I own a numbers-matching 70 Cutlass S. does anyone know which distributor this engine will be fitted with or, if possible, which Pertronix kit I'll need to order?
Thanks,
Anth.
Thanks,
Anth.
There are 3 levels, the Original, II, and III. Any one of them will work well it depends on what options you want included.
http://www.pertronix.com/prod/ig/default.aspx
I had it on the dyno and wasn't impressed. The timing marks were all over the place. The distributor had minimal clearance and the cam had .010-.012 end play. That tells me it was the module in the distributor. Imo I wouldn't use another one.
I think you will be fine. There seems to be a lot of debate as to the quality of Pertronix. I have had one in my boat for probably 15 years and it is still working. Mallory has been around forever and I would not hesitate to use one of their units either. I suspect they are both made in China.
rustycragars
Dec 25, 2016 06:06 PM
chris83
Aug 18, 2012 01:47 PM
dephconn24
May 8, 2012 11:05 AM
