Dip Stick Tube replacement
Old Apr 17, 2008 | 10:32 PM
Olds luvr's Avatar
Grown Azz Kid
Hey guys,
Quick question. I just noticed that the tube for my dip stick is broke unless it was a two piece design. It looks like it is seperated flush with the block so there is nothing sticking out from the block. My question is how to replace the tube? Is it a matter of pulling the pan and to get to the broken piece or was this a two piece tube?
Old Apr 18, 2008 | 05:25 AM
don71's Avatar
same but different
Some people have had success by screwing in a sheet metal screw that is just the right size. Then pulling on it with pliers.
I'm not that lucky..... so pulling the pan was the only option. A lot of work but tapped it out easily.
Old Apr 18, 2008 | 06:17 AM
2blu442's Avatar
Dip stick tube
I've had sucess with a sheet metal type screw and a slide hammer.
John
Old Apr 22, 2008 | 04:12 PM
projectheaven's Avatar
I had to pull the pan but it was worth it because I had to change the gasket on the oil pan anyway.Tapped right out from the bottom.
Old Apr 22, 2008 | 05:20 PM
Mine broke as well. I tapped it out from the bottom, but my engine was upside down on a stand.
1k442
Feb 6, 2013 02:16 AM
willj
May 16, 2011 02:54 PM
willj
May 16, 2011 10:11 AM
bulldog
Jun 8, 2010 06:37 PM
fmay50
Dec 17, 2009 10:45 PM
